Question about Canon PIXMA iP3000 InkJet Photo Printer
Power lamp always red. The waste ink absorber is full. Contact the service center for the replacement of the waste ink absorber.
    President:
  • 2,306 Answers
You need to have the absorber replaced at a shop where they can reset the count after changing the absorbers, otherwise ink could overflow and make a mess.
Posted on Aug 19, 2009
My canon printer 1p 1000 says the waste ink absorber is full contact service center
hi
you need to replace the absorber waste container. But to ensure you can work around this, do this first. Remove the square rubber at the end of the right side of your printer. Use cotton cloth absorb the waste ink. Clean and wipe the ink around area and place the absorber back into the tray.
Finally clean your print head by using dry cotton swab. If this deosnt work, try this: if it doesnt solve the issue, you must replace absorber waste ink tank .
  • You can manually override it, but I recommend getting it replaced.
    Reset waste ink tank counter CANON PIXMA iP 1000
    Disconnect printer from AC power
    Press and HOLD the POWER button, and connect printer to AC power
    release the the POWER button
    Press the POWER button again
please send me 4 thumbs up
Jul 20, 2011 | Office Equipment & Supplies
Computer says"Waste ink absorber is
What is the make and model of your printer (I'm guessing it is a Canon?)
May 06, 2008 | Office Equipment & Supplies
What is e 27 and e 8??
Those two are error codes, and they mean the following:
E8 - The waste ink absorber is almost full. Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and machine maintenance.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc.
E27 - Manual does not specify what this means, but tells you what you should do: Turn the machine off, and remove the power plug from the outlet. About ten minutes later, plug it in again, and turn the machine on. If the problem is not resolved, the machine may require servicing. Please contact your local Service Center.
You can read more about the error codes on Canon website.
Dec 02, 2010 | Canon PIXMA MP150 All-In-One InkJet...
"ink absorber is almost full, contact service center" - what does this mean?
Inkjet printer has waste ink absorber inside, sponge alike. The function of waste ink absorber is to localize and keep waste ink safe inside the printer and does not harm the electrical parts.
Waste ink is produced from print head cleaning process and borderless printing. When capacity of the ink absorber raise to about 90% then warning message appears.
You need to bring your printer to the nearest service center to get waste ink absorber replaced.
Source:
Printer Clinic: Printer Tips,tricks,troubleshooting
E-manualshop: Online source of service manual
Aug 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Printer won't print. Says to contact service
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Triangle and ON/OFF switch both flashing. Window reads 'CHECK PRINTER'. What exactly do I check? Window had been reading 'WASTE INK NEARLY FULL' for a fortnight, but I couldn't find out how to deal with...
The waste ink absorber is getting full.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc. http://support-nz.canon.co.nz/contents/NZ/EN/8000137103.html
Nov 09, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Printer light is blinking in orange & green
bassically your printer has come to the end of its life, you can either buy a new printer or contact the service center...
Jul 13, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Its appear " The ink absorber is full. Contact the service center."
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 11, 2009 | Office Equipment & Supplies
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA iP3000 InkJet Photo Printer Logo
53 people viewed this question
old marine
old marine
