Question about Microwave Ovens
How do you test the magnitron in a microwave?
  • Microwave Ovens Master
  • 9,085 Answers
Http://www.gallawa.com/microtech/mag_test.html
It can pass these tests and still be bad.
Only an experienced technician should do any measurements while the magnetron is under power.
Posted on Jul 20, 2009
I don't know why my frigidaire gallery microwave FMT118EPB goes on but doesn't heat
the magnitron supply EHT isnt there
or the heaters connections inside the square metal box
have come loose
replace the magnitron is best and check the eht fuse {inline type usually}
Aug 13, 2014 | Microwave Ovens
Kenmore 1000w Not Heating Food Items
If it sounds like it is running and it lights up it is not the fuse. In my 24 years of service work I've found that the problem you are describing is cause by the failure of the magnitron ( The device that emits the microwave radiation). As your unit is a built in expensive unit I would look into replacing the magnitron. In cheap microwaves I just suggest replacement. If you need further assistance locating a replacement magnitron feel free to cotact me. It is a relatively easy part to replace. You just open the case and unplug it, unscrew it from the unit, and replace it with the new one. In most cases all you need is a philips head screwdriver and some patience. Anyway, I hope this helps you out in your decicion.
George
Jul 19, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Microwave wont heat?
door interlocks micro switches
a duff relay on the control board
bad magnitron heaters {connections inside come adrift }
bad EHT to the magnitron
Aug 12, 2014 | Microwave Ovens
The microwave stopped heating up food. It acts as though it is working yet food stays cold. how do I test the magnitron ? Thanks
you have a major, board issue, magnetron don't fail that much, and if id did..the replacement cost exceeds the cost of the unit
Dec 19, 2010 | GE Advantium 120 Convection/Microwave Oven
I am smelling plastic and the temperature is rising.
If it's an older unit which does not allow any metal inside, there may be a piece of foil that is heating up causing any plastic it might touch to melt. Newer units don't have this problem and many have metal shelves. If yours is newer it may be the magnitron. The magnitron is the main component of every microwave.
Nov 19, 2010 | Microwave Ovens
It made a loud noise and was starting to smoke.
Sounds like the magnitron is shot, I wouldn't attempt to use it anymore. When a magnitron goes bad it actually gets much stronger than the unit is made to handle.
Aug 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
KitchenAid KHHS179lss, fried magnitron?
If your magnetron was shorted, the unit would not heat at all.
The sound of a shorted magnetron is usually a loud hum-- but no or very little smell and no smoke.
Components in the High Voltage section -capacitor, diode- give problems if they short out.
Feb 17, 2009 | KitchenAid KHHS179LSS Convection /...
Ge over the range microwave
well randy you might want to check the diode and cap with a meter first before getting the mag tube. if both of those parts are fine. replace the tube.
Apr 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
71 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
