Looks like it means changing the sensors. One some systems you can choose door and window sensors only and leave the room sensors, (passive infra-red or Ultrasonic) off. Both react to movement.
If all buttons are frozen then you have a hardware fault. The clear button should remove any error from the display so if it doesn't work at all, you need to have the keyboard checked. ---------------------
According to the crappy manual: -SE- An error of the oven may cause low performance and problems in safety. Stop using oven immediately and call service man. Means very little I know.
According to the Sony Service Manual for the PFM-500A3WU, 12 22 means
either the Plasma Panel has failed or the Power Supply has failed. 12
means "warning decrease of panel high voltage" and 22 means "warning of
decrease of middle panel voltage".ve had a look on other forums and someone as narrowed the 12/22 code
down to the (ic102) its only outputing 5volts its something to do with
the (b+ power supply)
