I am searching for a VIANO LED24DFHD TV Remote Code that is recognized by Xbox One to activate Device Control setting so ionly the Xbox One Media Control & replace all other remote contols for any connectted devices so no need to search for any controls setting it up to use only one.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Testimonial: "nopt correct information i was after. I want to control my tv all on my xbox one game console."
Alot easier solution is to enter VIVO in I Dont See My Brand the Select Guide Me to guide you through the rest once it your model select Enter Remote Code and it will Display the Remote Code in the Box to Enter if you ever need to set it up again or have another VIANO TV that you want to use. You will find it alot easier than the method above. If still having trouble contact me via email personally or on facebook above name at outlook to find the correct facebook i have enabled.
