Question about Cell Phones
My phone wont turn on
When i go to turn my phone on it will only pop up the greeting screen and then shut off and then do that over and over again and it will only stop when i take the battery out.
  • lexi_lucy_2 May 11, 2010
    does your phone have a full battery?
Set up voice mail
What model phone do you have and which carrier? For example, with a Verizon iphone 5 these are the steps:
  1. From the Home screen, tap Phone .
    The Home screen is accessed by pressing the home button (located at the bottom of the device).
  2. Tap Voicemail
    You could be directed to the automated Voice Mail system at this time. If so, follow the voice prompts to set up your Voice Mail and greeting instead of completing the steps below.
  3. Tap Set Up Now.
    If the 'Set Up Now' pop-up does not appear, your voice mail has already been set up. Simply tap Greeting in the upper-left of the voice mail screen and begin at step 6.
  4. Enter a password then tap Done.
    The password must be between 4-6 digits in length.
  5. Re-enter the password then tap Done.
  6. Tap Custom to record a greeting.
    To use a Verizon default greeting, tap (check) Default.
  7. Tap Record to begin.
  8. When finished, tap Stop.
  9. Tap Save.
Apr 11, 2016 | Cell Phones
My Iphone wont turn on
you have to hold in the button on the top to turn the phone on you have to hold that button in in till on the screen it just pops up either restart or shut down then you slide it will tell you to slide and then you see that your screen is just black so then you keep on pressing the button that you held in before and I apple will pop up and then you wait for your screen to come on and that is it but when the apple pops up don't hit anything just leave it in till the screen comes on.
Aug 25, 2014 | Apple iPhone Cell Phones
Can receive and answer calls but greeting announcement is silent.how do I turn on greeting.
Please tell me the model of your phone.However,you can do this with the use of your phone profile i.e from the phone click on it the screw down to the profile then click on it screw to setting or turn setting from there you will be able to get to greeting setting or turn from this step you will be able to activate the turn again .
Good luck.
Thanks for using fixya.
Sep 06, 2011 | Cell Phones
My phone keeps turning off when i turn it on....
remove your memory card and turn it on again.
your welcome
Jul 01, 2009 | Nokia 5310 Cellular Phone
Cant change my sanyo 6650 mobiles incoming msg font
here i hope this helps you Display Settings
Changing the Text Greeting
The text greeting can be up to 15 characters and is displayed
on your phone’s screen in standby mode. You may choose to
keep the phone’s default greeting (“Sprint”), or you may enter
your own custom greeting.
To display or change your greeting:
1. Select > Settings > Display > Greeting > Custom.
2. Enter a custom greeting using your keypad and press .
(See “Entering Text”on page 39.) (To erase the existing
greeting one character at a time, press .
To erase the entire greeting, press and hold .)
Changing the BacklightTime Length
The backlight setting lets you select how long the display
screen and keypad remain backlit after any keypress is made.
To change the Main LCD or Sub LCD backlight setting:
1. Select > Settings > Display > Backlight.
2. Select Main LCDor Sub LCD.
3. Select Always On, Dim Only, or a preset length of time.
To change the Keypad backlight setting:
1. Select >Settings>Display>Backlight>Key.
2. Select Always Off or a preset length of time.
Note: Long backlight settings affect the battery’s talk and standby
times.
Note: The Always On setting returns to the previous value the next
time you turn on the phone.
Your Phone’s
Please rate this solution thanks...
Jan 30, 2009 | Sanyo Katana II (SCP-6650) Cellular Phone
The screen is frozen and wont turn off or do anything
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Dec 01, 2008 | Philips GoGear SA3245/37 Digital Media...
Nokia N95 Support
Hello seems like your screen is broken. have you tried to plugin the video cable to the tv screen or something? if you get picture there it should be the screen that is broken.
Aug 14, 2008 | Nokia N95 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
