Question about Vizio L32 32 in. LCD HDTV
Vizio hdtv 32 inch wont come on.
It was working great the night before then next morning went to turn it on and it wont come on. no power lights or anything.
    Problem Solver:
  • 6 Answers
More then likey you have a bad mainboard. Especially for the 32inch and below its usally the mainboard rather then the powerboard.
The tv parts are modular you can usally buy parts on ebay. I dont recomend soldering or anything like that, just a simple board swap will do.
Posted on Jul 19, 2009
    President:
  • 1,077 Answers
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. Or, it maybe something simple like a blown fuse inside the TV. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 18, 2009
Dynex tv wont come on, the red light is on. Model
Does the red light come on and go off as you push the power button?
Dec 05, 2017 | Televison & Video
I need to know how to get my Emerson Flat Screen to turn back on.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Sep 11, 2014 | Emerson Televison & Video
My Vizio E422VL is only a year old. It has been working perfely fine and now it wont turn on at all. The remote and the on set switch don't work. Any suggestions?
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 03, 2014 | Vizio E422VL 42 in. LCD HDTV
Toshiba REGZA 40E200U 40 LCD TV wont turn on after it was working fine the night before.
Your TV needs servicing, Most likely you have a power supply related issue. Do you have any experience with electronics repair?
Sep 01, 2012 | Toshiba REGZA 40E200U 40" LCD TV
I turn the tv onblue light lights up (meaning power tv turn on) but nothing shows up on the screen. Was working fine one night and the next morning didnt work
Remove the power from the unit for a minute. Plug in and see if it works. If it does great if not continue.
There is a possibility that the LCD Lamp blew. To check this, turn the unit on. Look really close at it for a picture. The picture will be dark adn hard to see from a distance but it would be there if there is no damage to the main components. If there is a picture than either the lamp or inverter went, you will need to have it serviced or replace the unit.
If there is no picture at all then your unit may have had the tuner board go in it. This is a service only option. Best thing to do is take this to a tech shop.
Jun 13, 2010 | Televison & Video
I parked my Escalade last night. Now it wont start
there should be a fusable link which if it blows will give you those symptoms. sorry i don't know where it would be on your caddy.
May 26, 2010 | 2000 Cadillac Escalade
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Jan 05, 2010 | Vizio L32 32 in. LCD HDTV
No picture at all. had no problems until last night, turned TV on, and no picture. TV is VIZIO 32 inch LCD
Do you still get sound? If you do get sound, then the problem can be in the backlight inverter board or in the main power supply that supply 24vdc to the inverter board.
Oct 30, 2009 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
435 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
