I have a 2002 pontiac grand am gt 3.4 liter v6. The first time it happened was when i tried to recharge and run my ac and then 3 more times every time i tried to use my ac. Well i had to replace the hose that goes from my water pump to my engine, and after doing that i started the car to get it warm to check for leaks. I did not turn on the ac or heat or anything and after sitting and running for about 10-15 minutes it died. When i tried to restart it it wouldnt even turn over, my locks still work but nothing else and the fuse is blown again. I recently had my cooling fans replaced and the mechanic ran the wires to a small 10 amp fuse in the fuse box, could that be what is blowing it? Please help, i dont know what to do! Thanks
Get in an accredited auto electrician as there is a dead short to blow a 40 amp fuse
may be what the mechanic did is the problem but I think that it would have blown immediately if it was
I would be looking for a wire heavy size wire like to the alternator, or after the fuse box etc that is touching ground or a relay that is faulty
