Question about Protron PLTV-4250 42 in. LCD Television
42" Protron LCD TV
It would turn black...we would turn it off a while and then it would work when we turn it back on....now it has turned off for good. It is just not getting any power, we have tried everything. It has always been plugged into an expensive surge protect. Any suggestions?
    President:
  • 1,077 Answers
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common problem are the power supply for the screen itself. Most manufactures call it a Blacklight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 18, 2009
  • 3 Answers
This fix my problem: (Schottky Barrier Diodes) reads good Change it anyway
Posted on Aug 07, 2009
I have a Protron LCD 26" TV model#LT26CIPI...The tv was working great turned it off on night and in the morning turned it back on to sound but no picture just a Black screen...when you change channels
Since its a LCD take a flashlight and have the room as dark as possible and with the light look to see if a very very faint image of the picture can be seen or not---many of these sets use a "back light" for the brightness and if that's not on.......
Dec 11, 2012 | Protron PD-DVR100 DVD Recorder
My protron 42 lcd tv is not turning on the tv tries to power up and then it comes on and then just power down
Open the back cover of the television to check for dry soldering , if found resolder and power it on , if otherwise,
Your power supply board is not yet dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helpout......
Jul 07, 2010 | Protron PLTV-4250 42 in. LCD Television
42" protron lcd turns on and off by itslef
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | Protron PLTV-4250 42 in. LCD Television
Protron PLTV 42 IN issue
I have had the same problem off and on since I purchased my protron 42" lcd. I have found that if I hold the power button to the tv a little longer, I rarely have the problem. Hope this helps.
Jan 22, 2009 | Protron PLTV-4250 42 in. LCD Television
No video on my Protron PLTV 4250
check the video with a flashlight against the screen, if present the backlight inverter has failed.
Dec 07, 2008 | Protron PLTV-4250 42 in. LCD Television
Proron pltv-4250 no signal
THE BEST INPUT ON YOUR SET IS THE HDMI INPUT.2ND THE COMPOSITE INPUT. 3RD THE COMPONENT INPUT. AND 4TH THE ANTENNA INPUT. MOST DISH BOXES HAVE AT LEAST THE COMPONENT OUTPUT. YELLOW IS THE VIDEO AND RED AND WHITE FOR AUDIO. USE RCA CABLES TO GO FROM BOX TO LCD SET. ON THE DISH BOX YOU CAN GO FROM ANTENNA OUT TO THE CABLE OR ANTENNA IN ON THE LCD. SWITCH TV TO CHANNEL 3. AND TURN YOUR DISH BOX ON.
Nov 22, 2008 | Protron PLTV-4250 42 in. LCD Television
My PROTRON LCD PLTV 32 IS BLACK & DEAD
LOOKING FOR A AC ADAPTIR MODEL :090-02180-13
Oct 03, 2008 | Protron PLTV-32 Television
Protron 42
on the back of the TV where the power cord plugs into the back of the tv there is a small black on/off switch- it's not as obvious as you would think.... but that was turned off. Not sure how that happened since the back of the Tv was never touched when it went dead- but I unplugged the cord from the back of the tv and from the outlet and reset that switch and it worked.
Jul 10, 2008 | Protron PLTV-4250 42 in. LCD Television
Protron PLTV-4250 42 in. LCD Television Logo
553 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
