Question about Xtant A3001 Car Audio Amplifier
The overcurrent protection light keeps coming on; i am using the proper guage wiring and the correct fuse size i have adjusted the subwoofer control down on the deck and also the amp itself, the deck is only pushing about 4volts back to the amp and there is no line driver.
  • berghammer23 Aug 25, 2009
    There is virtually no dust in it I check it out about every two months; and the board looks great, the connections are good and there is no discoloring anywhere inside. Good suggestion with the dust not a lot of people think of that.
    President:
  • Xtant Master
  • 1,114 Answers
How long has it been since you cleaned it with dust off? Xtant say's once a month. Dust can create a big buildup of static on the boards and anything is possible. Hope this helps
Posted on Jul 18, 2009
  • Frank Fulton
    Frank Fulton Aug 25, 2009
    I can't remember if you said you had checked the voltage at the amp with it running or not. If Xtant sees power less than 9.6v it will shut down. Also, what impedance are you running the amp at? lower than 2 ohms? if so, current demand almost doubles and it will shut down faster if voltage drops below 11. If your still having issues, I have a few friends in the biz and I can get some direct advice from Xtant. Let me know.
What size fuse amp do ineed 4kompesser2000 driver seat ajustment
Fuses are incorporated in circuits for a good reason; to protect components and wiring in the event of a current overload.
If a lower rated fuse is installed in a circuit, it will blow under normal load conditions as it is rated for lower power usage.
If a higher rated fuse is used in a circuit, it would not blow before a overload causes damage to circuit components or causes a overheating condition and possibly a fire.
Therefore, it is essential that the correct fuse be used in the circuit it was designed for...
Your particular auto may have a fuse diagram in the owners manual, or printed iside the cover to the fuse panel - if not, ask a dealer for the correct fuse designation. The fuse diagram should show the size fuse needed for the seat controls.
IF the fuse you are blowing is the correct size, STOP using the seat controls until you have the problem troubleshooted by the dealer or a good mechanic.
Good Luck. JWM
Feb 22, 2015 | AMP Fuse Wiring Panel
I have 1985 GMC 4/4 it keeps popping fuseable link on fire wall I have checked all the wiring. The red wire that into the fire wall the fuse block show to have direct short when the ignition switch is
I'm not sure which one you are talking about, if I remember correctly there are 2 on the firewall. One is a 16 guage wire which protects all red 12 guage wiring. The other is a 20 guage wire that protects the generator warning light and the field circuitry on the alternator. It will be protecting a 16 guage wire.
Sep 01, 2014 | 1985 GMC K1500
What size wire should i have for two 12 volfenhag subs
I would use 10 to 12 gauge wiring. As fare as your amp's fuse...Check to make sure you are using the correct amp fuse. Make sure your subs are wired to a ohm load your amp is stable with. Check your ground and positive connections. Check and make sure your amp's gain settings are correctly set. Your amp's gain should not be turned all the way up.
Sep 25, 2012 | Volfenhag ZX-4712 Car Subwoofer
What makes the bass1500 stay in Protection mode????
Ok, usually a fluctuation in amperage trips the protection on an amplifier. To start, check your ground. This is typically the problem. Use a multimeter to ensure that the ground you have is good. Second is the guage of wire. Look at the fuses on your amp. Add them together and use that as the amp draw total. 50-65 amps from 13 feet to 22 feet run of wire requires a 4 guage. If the draw is larger, you may need larger guage wire. Also, match the ground wire with the power wire in guage.
Happy Hunting
Aug 14, 2011 | Car Audio & Video
My audiopipe amp went into protect mode randomly. even though i have to prevent fuses on my power wire
Ok, for starters you need to clarify if you are saying you have "two" fuses on your power wire. That's what I get from your statement. My question would be why? As long as you place the initial fuse within 12 inches of the battery, you're cool. The purpose is to stop the flow of power in the event of a spike so that your power wire doesn't fry and cause a fire under your vehicle carpet. Second, your amplifier should have fuses that trip when this occurs too. If this has been occuring since you installed the amp, you need to recheck all your wiring (I recommend removing the extra inline fuse). Two things trigger an amps safety mode. 1- an amperage fluctuation or overload. It will sense when there is to high or too low of an amperage flow. Too much fluctuation can damage internal components. 2- Your amp is malfunctioning. If you have an internal short, this could occur. (really it's tied to the first one because it is sensing that the short is allowing a full flow of power at the short, thus causing a fluctuation). Start with the ground wire. Most amperage problems happen because of a poor ground. Think of power like water. If you have a good flow coming in, but poor flow going out, it gets kinda....backed up. This causes a fluctuation of the amperage since the electrons cannot flow properly. Setting off the protection. The other thing to thing about is the correct guage of wire. If you have too small guage wire, the amperage will dip low during heavy usage, causing the other extreme of the fluctuation.
Check what you have. If you are running a load of 50-65 amp (look at the fuses on your amps and add them up), then 4 guage is good from 13-22 feet. If you are running any higher than that, you will need 2 or 0 guage wire. You will also need to make sure to have a fuse slightly higher that the amperage draw you are expecting. As always, make sure your power and ground wire match. I have seen alot of kits made with smaller guage ground wire. They work of the premise that the shorter distance produces less resistance, thus requiring smaller guage wire. I say why risk it. Always use a multimeter when checking for proper ground placement. Also, if you are going to use aluminum or tinned wire (trust me, it's out there), you will need to increase the guage of the wire.
Happy hunting
Aug 14, 2011 | Audiopipe Car Audio & Video
The protect light wont turn off, so power light wont come on
OK, I am assuming that you are talking about an amplifier, right? If so, check the wiring. An amplifer's protection senses fluctuations in amperage load. This is a good thing. It's saving your amp from frying, so don't be mad at the amp. Start with the ground wire. This is typically the source of the problem. If you know how to use a multimeter, use it to ensure that your ground is a good position. If you solve this, look at the guage of wire you are using. 50-65 amp loads from 13-22 foot runs are acceptable for a 4 guage wire. If you are running 8 guage for this, you need to upgrade your wire. Look at your amp. Check the fuses. The numbers on the fuses, add them up. You can use that as a bases for your amperage load. Also, is your remote wire allowing the amp to turn off, and thus reset? Something else to think about. Happy Wiring
Aug 12, 2011 | Car Audio & Video
The protection light keeps coming on
That means something isn't wired right. Make sure that all of the power inputs from the battery are correct. Most importantly make sure no bare wires are touching (IE the positive and negative bare wires going to the subwoofer terminal.) If it keeps persisting, check the voltage level in the car and make sure it is normal, because some fancy amps have protection where it will go into protect mode if the amplifier is not getting enough power to supply. Also, does this happen when you are really bumping (like high volume) or just the second its on it cuts? Because when you really play it loud and it cuts, sometimes you are putting too much a load on the amp. Make sure the fuse in the amplifier is the correct fuse for the amplifier.
Oct 13, 2009 | Jl Audio 500/1 Car Audio Amplifier
I have an american legacy series 2 1000watt apm
Check and see what size fuses it uses. Your watt power means nothing without good fuses. My suggestion would be to go buy 40a fuses and replace the ones you already have.
Feb 27, 2009 | Legacy Audio American Legacy II LA290 Car...
Protection light coming on and amp cutting off
yes make sure there both connected properly, check the fuses, the protection light usualy comes on when there is too much power and the amp protects itself from blowing
Jul 16, 2008 | Car Audio & Video
Protection light
You cannot parallel two subs AND run them on the Bridge. You must have at LEAST a 4 ohm load on the bridge, and 2 4 ohm subs in parallel equals TWO OHMS. BAD!!! Move each sub to it's own channel or your amp will soon fry.
Sep 10, 2007 | Sony XM-2002GTR Car Audio Amplifier
Xtant A3001 Car Audio Amplifier Logo
304 people viewed this question
Top Xtant Car Audio & Video Experts
xxxxxx xxx
Are you a Xtant Car Audio and Video Expert? Answer questions, earn points and help others
