Sewing Machines Logo
S
Sharon Brace Posted on Jul 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just recieved an older kenmore 24 stitch sewing machine and it has no manual with it , my problem is why wont the machine pick up the bobbin thread ?
I had to refill the bobbin and i put it back in but i must of put it in wrong some how because now the needle will not pick up the bobbin thread before that the machine work pretty good. What did i put the bobbin in wrong because it looks streight forward to , you just drop it in dont ya
R.A. Ellis
Level 3:
  • Kenmore Master 12,731 Answers
  • Posted on Jul 11, 2016
R.A. Ellis
Kenmore Master
Level 3:
Answers
12731
Questions
Helped
2605322
Points
59175
You can probably find a manual from Sears. They carry a ton of Kenmore user manuals.
First thing to always try--insert a brand new needle!
Bobbins do usually have a specific way of being loaded. Most machines require the bobbin to be inserted into the bobbin case so when you pull on the thread tail, the bobbin turns clockwise (this is when you are looking at the backside of the bobbin case - at the bobbin). Also, be sure to thread the bobbin thread through the bobbin tension mechanism.
Tip how to put bobbin into the bobbin driver on sewing machine
If the upper thread is not picking up the bobbin thread, it is usually because there is a timing issue (means the needle is arriving at the bobbin at the wrong time to connect with the bobbin thread).
Sewing machine won pick up bobbin thread hook timing fix
P.S.--if your Kenmore is non-computerized (ie, mechanical) be sure to oil using fresh, good quality sewing machine oil or Tri-Flow Synthetic Oil (NOT cooking oil, 3-in-1, WD-40, or old stinky brown stuff that may be in the accessory box). Apply a couple of drops every place metal rubs on metal (while hand-rotating the handwheel). Do NOT oil nylon, rubber, or belts!
I have lil sew % sew LSS505+. the needle won't catch the bobbin thread so won"t sew.
Make sure the need is in correctly. if it is backwards or turned to one side too much it wont pick up the bobbin thread. If the needle is in right and it still wont pick up the thread then the machine is out of time.
1helpful
Wont pickup bobbin thread when sewing.
Make sure you are using a brand new needle. Bent/damaged/dull needles frequently will fail to pick up the thread.
If it continues to skip stitches, it most likely has a needle/hook timing issue--the needle arrives at the bobbin at the wrong time to intercept the bobbin thread.
There are web sites and videos available that discuss sewing machine timing, or you can take it for service.
2answers
Machine wont sew. Misses stitches
check for problems in the bobbin winding, ( in the wrong way so that the thread is not coming out correctly)
top thread tension too tight or too loose
vary the thread tension to see when it improves on a waste test sew
2helpful
2answers
Kenmore 100 stitch 385 Bobbin thread does not engage into stitch, Needle goes down but thread does not pull up into stitch. Threading bobbin according to diagram on foldout section. replaced the bobbin...
make sure that you have enough of a tail on your thread, at least 3-4 inches and hold it with your left hand until the needle picks up the thread. I am assuming that you have your bobbin threaded correctly and your needle is inserted with the flat side facing the rear of the machine.
I have a kenmore 385.1884180 sewing machine. The other day I ran a couple of seams to see if the machine still worked as I have not used it in a few years. And it stitched just fine. Today when I go to use...
Make sure that you are doing the bobbin right, by that I mean, make sure that the thread is in the tension spring and you put your finger on the bobbin and pull the thread up, now bring down your needle to hook it. Look at your manual. If, you don't have your manual, go managemylife.com and download for free
I have an older kenmore sewing machine. It's been
When I have run into similar problems with my older Singer, it's because there is a bit of thread caught somewhere in the bobbin mechanism that doesn't allow the shuttle to run freely. Take the bobbin assembly apart and use a bright light to see if you see any bits of thread in there.
Good luck and let me know if this works!
Old Kenmore 158. bobbin issues, thread clumping and such
problem is always on the opposite side of the fabric, in your case the machine is not threaded properly.
2answers
Stitch pattern not proper
be sure that the thread is routed properly. Then check on the bobbin holder, it may be defective.
3helpful
2answers
Machine wont pick up bobbin thread
needle won't pick up thread I think the timing is off, how do I retime it?
Top Kenmore Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
