Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Craftman 42cc chainsaw, need to know how to fix the oil pump or check it and we need a manual, not getting oil to the chain just drips out
  • 154 Answers
Remove bar and chain, run saw to see if oil seeps, if so need to clean bar well
Posted on Aug 03, 2009
Poulan Pro 42cc 2-Cycle 18'' Gas Chain Saw excess oil on chain
are you using a chain bar oil as this is a lot thicker than normal engine oil
Jul 16, 2012 | Poulan PP4218AV 18" Chain Saw
Not pumping oil to chain, bought a new pump and oil pickup but I`m not sure where the oil pump is located and what I have to disassemble to get to it.
Most oil pumps are situated behind the clutch and sprocket, these will need to be removed before you can acsess the old pump, if it has an inboard sprocket you will need to remove the clutch first, these are a left hand thread and just spun onto the crankshaft, they need to be jarred off against the compression of the saw, you may need a special tool if there is no nut on the outside of the clutch, this tool fits most Poulon clutches 530035560, once removed it is a fairly straight forward job to change the pump.
Sep 13, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
No oil getting to bar and chain..
The oil pump is run by a worm gear that will strip easily if the oil pump becomes clogged. You'll have to remove the bar and do some disassembly on the saw, but it is possible to fix. You can buy the replacement parts kit (that comes with an instruction sheet) from poulan for about 20 bucks, just call the number on the saw.
Sep 05, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My poulan is not sending oil to the chain, i tried taking air to it and cleaned it out.
The oil pump has a worm gear that strips easily if the oil line clogs. You will likely need to replace it.
Aug 30, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
No chain oil is getting tobar. I've checked for blockage and cann't find any.
Very good chance that your oil pump has a stripped gear.This often causes the oil pump to stop working on these models.
Feb 20, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Craftman Chainsaw do not run
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button HTH
Lou
Oct 20, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Need owners manual for 2.2cu in sears craftman chainsaw
Download the PDF version from http://www.hammerwall.com/Manuals/Craftsman/Description/358.352161/Craftsman%2016%20Inch%20Bar%20Gas%20Chain%20Saw/L0708268/
Aug 27, 2009 | Garden
Chain moves while idle
Hello there. Regarding the bar oil, many loggers plan their work so that they are out of bar oil at the same time that they quit for the day because bar oil has a tendency to leak. Another method that has some success is to mix your bar oil with a heavier oil but the trade off might be less lube getting to the chain when you need it.
Regarding the chain moving in idle, this is another common problem. You can usually slow the idle down until the chain stops, as you indicated, but I too have had chain saws where I finally just decided to live with it and be extra attentive to what was going on.
Jun 11, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 2550 chainsaw does not lube the chain
sometimes the oi lpumps fail or get clogged youll have to take it apart and replace/clean the pump. let me know if you want more instructions on this
Apr 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
295 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
