Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Intex system not giving chlorine, no errors but no green light
I bought the intex system mid last season, seemed to work great last year, this year i'm still trying to get it to work. I thought it was working fine for weeks until my pool turned green and I checked and had no chlorine. Been running it 6-10 hours and still no chlorine despite no warning messages, it looks fine. So did clean and soak in vinegar as suggested, there was quite a bit of build up, thought that solved the problem. But alas no! Again it counts the hours down, gives no message but no chlorine. Also just realised last year I had a green light, this has not appeared this year at all!
I found I had the same problem. I would set the hours, it would count them down but the green light would NOT come on indicating it was producing chlorine, yet the sleep light would light up after the count down so I knew the light was working. I checked my salt, made adjustments, had to do shock treatments to keep it clean. Today I  found out that the manual is incorrect in how it says to set it. After you set the hours, instead of pushing both the arrows at the same time until it beeps, push the down button until it beeps, and then the up button until it beeps. For 2 months I have fussed with this system, and finally the green light came on and my test strips indicate it is producing chlorine. Yeah! To bad intex does not seem to mention this on their web site.
Good Luck
Posted on Aug 02, 2009
    Scholar:
  • 86 Answers
I bought one of these salt water systems last summer and was excited to not have to use chemicals again. I took the unit back about midsummer as it was not producing chlorine like they said it would. I immediately went back to chlorine and other chemicals, (that of which I wanted to get away from) but at least now I know my pool water is clean. Not salty and lack of proper clean water.
We then bought a sand filter system for our intex metal frame pool and couldn't be happier. The intex pumps (salt or none) just aren't efficient enough for the pools they come with anyway.
Posted on Jul 29, 2009
  • 3 Answers
Had similar problem. Took it in to the dealers and they said it was kaput and kept it. Said to buy a new one - $350. Been through 2 of these in 3 seasons. Was considering buying a "real" salt chlorinating system where the replacement cells cost about $350, but I'm thinking it's probably cheaper and easier (need to set up some kind of pipe adaptation system) to just use the Intex ones for a year and replace them, much as I dislike condoning the throwaway solution!
Posted on Jun 24, 2013
How do an intex pump to a non intex pool?
this question has come up before too me , what i respond with is it to be perminate or temporary ? , the reason i ask if its to be perminate then i suggest purchasing the correct filter for the pool, but on temporary situation (to just finish out season) then yes even though the pipe sizes are different , the use of std plumbing home DWV rubber soft connections available at any good hardware/homecenter would work , but heres the temporary part of it , saltwater pool water degrades the rubber making it brittle , but will last a month or so
May 30, 2012 | Intex Salt Water Saltwater System Chlorine...
We have a 15' by 48 " pool with an Intex saltwater chlorinator.About two weeks ago the low salt light started flashing .We ended up adding way too much salt (160 lbs)because the low salt light kept...
First of all green water can arrise from a lot of different situation.
Low chlorine is one of them coupled with the crappy filter that comes with the intex pools it does not filter enough.
Start with getting your salt level to 3000ppm
any lower than 2700 and you will not generate enough chlorine and any higher than 3500 and you could go cloudy or trigger high salt alarms
you need to get the salt test kit that reads in #'s not color the color ones has to much of a variance
once your salt is at 3000 clean your cell then filter filter filter
I run my filter 24/7 if it is not generating chlorine I am filtering.
Clean your cartridge every few days
I have had the same 2 cartridges for this being my 4th season and have never been green or replaced the filters.
Also I reccomend a non foaming algecide
Just follow directions on bottle
Aug 29, 2010 | Intex Automatic Salt Water System for ...
My water was crystal clear when delivered. I added the salt, ran the filter pump for 24 hrs as instructed. Turned on my Intex saltwater pump and within an hour water is green. Cannot find anything on...
I am not impressed at all with these salt water chlorinators.Shock the water and keep the filter running next day add a powdered chlorine.filter still running. check the balance with test strip in about four hours.If chlorine level is good start vacuming the algee off the bottom of the pool. Now throw away the salt generator and stay with the chlorine packs every week to two weeks continue to monitor with test strips
Jun 17, 2010 | Intex Automatic Salt Water System for ...
System shuts off and will not chlorinate
check or replace sensor and check cell if ok possible bad transformer
Jun 20, 2017 | Intex Automatic Salt Water System for ...
No warning code, green light on but no chlorine produced???????
make sure your ppm is at least 3000 low salt may not trigger an alarm but is not sufficient for generating chlorine
also make sure you are running the generator for at least 4-6 hours to give the chlorine time to register
the system itself blows out very minute amounts of chlorine but build up after hours of being on
Jul 20, 2009 | Intex Automatic Salt Water System for ...
Green light not working on Intex Saltwater System, model #8110
It is easier to explain than to type it all out you can call me at 586-625-2300
we have never had any issues with water clarity
in general I will say you are not filtering enough in normal mode
Mark
Jul 08, 2009 | Intex Automatic Salt Water System for ...
Intex saltwater chlorinator not working. Checked
IF YOU HAVEN'T HAD IT A YEAR , RETURN IT TO INTEX FOR REPAIR
Jun 17, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
1,031 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
