Question about Radio Shack Pro-95 Handheld Scanner
I get all channels locked out. How do I unlock the channels.
  • 27 Answers
You are pressing the "scan" button in the upper left hand position and getting all channels locked out? Correct?
If you haven't programmed any frequencies the channels will stay locked out. Get your local frequencies by doing a search for police scanner frequencies. Once you have gotten the information for your area press the "PGM" button on the lower right hand side of the key pad. Input your 1st frequency ###.#### then press "ENTER". Press "PGM"key again and enter your 2nd frequency then "ENTER" again. Repeat as often as you wish to enter more frequencies.
When you are done, (you can stop any time) press the "SCAN" button in the upper left hand position and you are in business. You are supposed to be able to choose which memory position you wish to use but I haven't tried to figure that one out.
If you need the manual for the radio go to radioshack site and do a search for PRO95 and it will come up in PDF format.
Hope this helps. I have owned the pro 95 for maybe 6 or 7 years and after doing a little programming yesterday the thing is much more to my liking. It scanns quicker and scans the channels I wish to listen to.
Posted on Jul 31, 2009
  • JDBgn Jul 31, 2009
    Try not to write over a previously entered frequency unless you decide you don't want to listen to it any longer. Watch in the lower right hand side of the screen to make sure you are entering your next frequency in the next empty channel.
  • 27 Answers
You are pressing the "scan" button in the upper left hand position and getting all channels locked out? Correct.
  • 127 Answers
Hello hope i can help you. you well need to go to each channel and you should have a button l/o push button and it should show that it has been unlocked. I do know if you have old frequency # it well lock them out. if i can be of more help and i will try and find you a manual for it if you need it.
Posted on Jul 18, 2009
My 42 FD 9954 Philips flat TV monitor has a channel lock I can't get it unlocked what do I do
How to lock or unlock channelsTo lock or unlock channels:
  1. Press the Menu button on your remote control.
  2. Select Settings.
  3. Highlight System and press OK/Select.
  4. Select Parental/Purchase.
  5. Enter your Parental Controls PIN.
  6. Select Parental Preferences.
To lock or unlock all channels:
Select Lock All or Unlock All and press OK.
To lock or unlock specific channels:
Select Block by Channel > Add or Remove Channels.
From there you can select to Lock All, Unlock All, or
select specific channel(s) that you'd like to lock or unlock.
Jul 21, 2015 | Philips Televison & Video
How do I unlock scan mode and all channels they are lock
  1. Press Hold.
  2. Enter the channel number you want to unlock and press Hold again. (You can also press Hold and scroll to the channel.)
  3. Press l/O. L/O (or TL/O) disappears.
Unlock all Channels in Banks Currently Enabled for Scan
  1. Press Hold to stop scanning.
  2. Press and hold l/O until Confirm Unlock All Channels? appears in the display.
  3. Press Pgm/E to unlock all or . Clr to cancel.
Mar 04, 2015 | Uniden BC 125AT
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
I have the BC370CRS SCANNER I am trying to clear all the memory and reset it. It is telling me to hold down 2, 9, and hold and turn it on. That is not working. Can you please tell me another way to do...
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again. Restoring All Locked Out Channels You can restore all locked-out channels in a bank only when the bank is selected for scan. Follow these steps to restore all locked-out channels in a bank. 1. If you de-selected the bank, press SCAN then press the bank's letter. 2. Press MANUAL. 3. Hold down L/O for about 2 seconds. The scanner beeps twice and unlocks all To delete a stored frequency, press 0 then press E. Channels with no frequencies are automatically locked out hope this helps
Mar 29, 2011 | Uniden BC370CRS Base Scanner
Bc898t all 500 channels are locked out. How to unlock all of them
Mar 29, 2011 | Uniden BC898T Base Scanner
Channell lock
i find out that some channel are locked on my telivision with a padlock sign. How can i unlock this channels
Aug 24, 2008 | Curtis CM25101S 25" TV
Sanyo tv kit 360 ch fit in my old tv & lock channel kindly solve problem to unlock tv channel
i am imran
and i have also buy sanyo tv kit 360 ch fit in my old bpl 20"tv and i know for unlock tv channel.
try this this code definetly is solve your problem.
1st go to the locked channel.
and then press menu>system>child lock
and then press and hold down tv/av key and press swap key.
and see locked channel is unlock.
i have coming soon post for service code menu in short coming days.
please reply me to imr4@in.com
Aug 12, 2008 | Sanyo DS24205 24" TV
All channels locked out pro-2055
I hope this will help. It shows locking and unlocking ids while scanning and while in a bank.
Locking/Unlocking IDs Contents You can lock out IDs you don't want to hear such as telemetry, MDT's, dog catcher, etc. To Lock out an ID while scanning, quickly press L/OUT while the ID is displayed. To Lock or Unlock an ID manually: 1. In Manual mode select any channel of the bank you want to lock or unlock an ID in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel. 2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the bank number (0-9), list number (0-4), and the list status (ON or OFF) on the 1st line, the ID# in the list (0-29) on the 2nd line, the ID on the 3rd line, and bank tag on the 4th line (if programmed). 3. Press TRUNK (each time) to select the ID list (0-4). 4. Select the ID# (0-29) by pressing up.jpg or dn.jpg (or press and hold; faster) then press L/OUT to lock or unlock the ID. An L will appear to the right of the ID# if the ID is locked out. 5. Press MAN to exit programming. To Unlock IDs in a bank: 1. In Manual mode select any channel of the bank you want to view the locked out IDs in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel. 2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the ID list. 3. Press FUNC then L/OUT (each time) to view the locked IDs. Press L/OUT to unlock the ID. The next locked out ID will appear. 4. Press MAN to exit programming. Note: You cannot unlock all IDs at one time.
Nov 18, 2007 | Radio Shack Pro-2055 Base Scanner
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Radio Shack Pro-95 Handheld Scanner Logo
379 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
