Washer only fills part way before agitation begins
I have a kenmore washer 110.26842691, and when I turn it on, it only fills part way before agitating, all else seems to run fine, but this one problem.I can hold the reset button to get more water in the tub, but I have to repeat that step for the rinse cycle also. Any suggestions before I call a repair man?
    President:
  • 1,776 Answers
The water level switch regulates your washer's fill volume. The switch is usually a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises the pressure increases on the air in the tube. When the pressure reaches a certain level, it activates the switch to shut off the water, and signals the timer to start the agitate cycle. If the switch is defective it may prematurely signal the water to shut off. If so, you will probably need to replace the switch. Hope this helped.
Posted on Jul 18, 2009
Will not stop agitating, timer will not advance
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.20922990
As you say, I'd also suspect that the timer is not advancing.
Following is the Whirlpool / Kenmore service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 28, 2009 | Kenmore 22062 Top Load Washer
The washer fills and then no agitation begins - it has no electrical, I think
Check the lid switch. That's a safety interlock that keeps the agitation from starting with the lid open. If the switch is bad, or if the actuator is not properly contacting the switch, then the machine will just sit there after it fills.
Oct 19, 2009 | Kenmore 24632 Top Load Washer
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Washer keeps filling with water...
you hae a stuck float switch, it shuts water off when it reaches a certain height, fixing it involes removing the top of the washer (not easily done)
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Washer will not agitate. After starting the washer the water will begin to fill but when it's time for the agitator to begin it shuts the whole machine off.
If the lid lifts up from the front, tighten the hinge screws on both sides of the lid. If the screws are tight open and close the lid..listen for a click.. no click..lid switch is bad.
Jun 12, 2008 | Kenmore Washing Machines
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Calypso Washer agitator malfunction
you either have too much stuff in it or something that gets under
the agitator or it has a weak transmission
Mar 16, 2008 | Washing Machines
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Begins to agitate but stops
The motor could be drawing too much current and causing the overload relay to trip. You will need to get an authorised techinician to test the motor.
Nov 01, 2007 | Kenmore 93702 Top Load Stacked Washer /...
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
