Question about HP Photosmart M407 Digital Camera
Camera no longer does anything when the "zoom in" or "zoom out" feature is used. can't move the menu bar to the right, only to the left?!?!
    Problem Solver:
  • 6 Answers
Sad thing about point and shoot cameras they have a somewhat short life span and these types of issues are common.If you enjoy shooting I suggest a digital SLR camera.Factory service on a point and shoot can and probably will cost more than you spent on the camera when it was new.
Posted on Jul 18, 2009
I like to get up close pics of objects especially plants and scenery. The problem is when I zoom in the picture is always blurry and cannot focus on objects that are not far away. Is there anyway setting...
most cameras come with an option called macro,this setting is for close up shots.on your camera it needs to set at wide angle.when choosing the shooting mode move left or right and choose the icon of a flower.if you adjust the zoom, a zoom bar will appear at the top of the lcd.if you try to use a zoom not intended for macro shots the flower icon will gray out and the bar will appear yellow,if you take a picture with the yellow bar it will be blurry.if you zoom out a little until it stops you should be ok. if you use a flash in macro mode the images edges usually will darken.hope this helps.
Jan 08, 2011 | Canon PowerShot SX100 IS Digital Camera
Model sd1100is How do I remove date stamp to enable digital zoom feature? GC
You can do either, or both. They are not mutually exclusive.
Aug 11, 2008 | Canon Cameras
Zoom, Menu/OK, up, left,right all don't work but
Try moving down, and then moving up. Similarly, try moving the opposing directions for left and right. If there is no way to go in a certain direction, on a certain screen, it will appear that the button isn't working. I think you can solve it now. I have faith in you.
Apr 22, 2010 | Fuji FinePix F460 Digital Camera
Digital zoom using powershot sx10is
On shooting mode, press MENU,then move down to Digital Zoom. Use right or left buttons to change the digital zoom options. For example: you can set on 1.6x, 2x, etc.
Jun 06, 2009 | Canon PowerShot SX100 IS Digital Camera
How to use the Zoom
I assume you mean when pressing the W or T buttons the zoom feature does not work. Try to reset the camera to the factory default settings and this should enable the zoom feature to work again. To do this go to Ok button and then to Mode Menu - then to Setup tab and then right arrow to Reset. hit the right arrow and you will see Reset Yes or No. Highlight Yes and press Ok. Camera should be in factory settings and zoom option will function.
Nov 13, 2008 | Olympus Stylus 600 Digital Camera
I have the lg env2 and i can not figure out to zoom in and out on the camera and it not the arrows
You need to make sure that your camera isn't set in the highest setting. Otherwise there's no zoom available.
Aug 11, 2008 | LG Cell Phones
Instruction in manuel nor very clear hard to understand
ok to Delete a picture when your looking at the picture click the center button then a bar comes across the bottom. the first one on the bar is Delete, click center again then to delete ONE click down to delete ALL click up. same with videos. and to zoom in there are 2 buttons joins with T & W on them. T is zoom in and W is zoom out :D
Dec 30, 2007 | Jazz DV-179 Digital Camera
Manually focus the C-5500 Sport Zoom
Occasionally it is necessary to have the ability to manually focus a digital camera. A good example is shooting through the windows of a tour bus on a rainy day. The camera may choose to focus on the raindrops on the window rather than the actual subject. To enable the MANUAL FOCUS function hold down the OK/MENU button for a second or longer. In the lower left corner of the LCD screen you will see MF (MANUAL FOCUS) and AF (AUTOFOCUS) with AF highlighted in green. Use the left arrow key to select MF. You will now be able to use the up and down arrow keys to manually focus the camera. An added feature of the C-5500 is that when you are using the MANUAL FOCUS Mode you will see a magnified portion of the image in the center of the LCD screen. To get out of MANUAL FOCUS Mode, simply use the right arrow key to reset the camera to AF. Then press the OK/MENU button to return to the default functions.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Press the OK/MENU button and then press the right arrow button to enter the Mode Menu. Press the down arrow button until the SETUP tab is highlighted. Press the right arrow button and then the down arrow button until PIXEL MAPPING is highlighted. Press the right arrow key, which will highlight START. Press the OK/MENU. The back of the camera will display an indicator bar with the word BUSY. Once Pixel Mapping is completed the Mode Menu displays. Press the OK/MENU button to resume normal picture taking. The bright dot should no longer appear in your downloaded images.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Shooting features
There is an option where you can set the camera to capture two images side by side, within the same frame. This feature is called “2 in 1” and can be accessed through the Mode Menu. Press the OK/Menu button, and use the right (>) arrow key to access the Mode Menu. Press the up (^) or down (v) arrow key to navigate to the CAMERA tab and then use the right (>) arrow key to access this sub-menu. Use the down (v) arrow key to navigate to the “2 in 1” feature and by using the right (>) arrow hey the “2 in 1” feature will be active for the next two shots. After the second shot the camera will display the menu option for “2 in 1”. You can select the option again, or you can return to normal shooting by pressing the OK/Menu button.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
HP Photosmart M407 Digital Camera Logo
74 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
