Question about Nikon LS 2000 Film Scanner
  • tip4906 Nov 21, 2008
    I have the same problem except that I didn't get the SCSI card necessary for the computer. THe cable that came with the LS-2000 fits the scanner perfectly but has a 25 pin connector on the computer end that fits a parallel port but it can't run off a parallel port can it? So what sort of card can I get that will let me connect that 25 pin cable?
    Tip -
This scan works with SCSI interface not provided by default in PC. So scan uses to come with SCSI board .. you need to install it into your PC .. yes
Posted on Dec 20, 2007
One cable would fit into my pc the other into my monitor- that is how i'd hook up my 640 p acer flatbed scanner for xp windows. cool. now ive changed my monitor and it doesn't have a port. what do...
If your pc is lack of usb port. You can buy usb card to enhance usb port in your pc to connect your scanner...I presume that your scanner is usb supported cable
Sep 19, 2011 | Acer ScanPrisa 640P Flatbed Scanner
My LS-2000 film scanner has just stopped working
I read this forum entry and it solved my problem also:
Dec 03, 2009 | Nikon LS 2000 Film Scanner
Coolscan 3 and Windows XP
Try a good scanner program called vuescan. Much better than Nikon software. I have been using on XP for a long time and no problems
Mar 25, 2009 | Nikon Coolscan III Film Scanner
Nikon scan was unable to find any active devices
The LS2000 is older than XP and has some fairly tight requirements to work. The recommended SCSI adapter is an Adaptec 2906, and you will probably need to backrev the ASPI layer driver files to version 4.7 (available on site). You may need to boot in Safe Mode to remove the later versions of the ASPI files before you can install the 4.7 files. You will also need to update your Nikon Scan software to version 3.1.2, available online by googling "nikon scan 3.1.2".
Mar 22, 2009 | Nikon LS 2000 Film Scanner
Dell laptop wont recognize ls2000 scanner
The LS-2000 is a "legacy" device to XP and the Nikon software. It needs to be connected to a true SCSI bus adapter, and it's actually pretty finicky about which ones will work in XP. Sorry, you won't be able to use this with your laptop.
Feb 28, 2009 | Nikon LS 2000 Film Scanner
I need to connect a Nikon LS2000 Slide Scanner to a Power Mac G4
I originally had the same problem but with a G5. Since Nikon never updated the software for the LS2000 to work with Apple I ended up buying a FR1SX adapter from RATOC Systems: connects the SCSI pins to a Firewire cable. Then I purchased the VueScan software from The scanner worked for several years with this combination.
Dec 17, 2008 | Nikon LS 2000 Film Scanner
Connecting a Nikon LS200 slide scanner to a PowerBook G4
Yes - get hold of an Adaptec USB2XCHANGE SCSI-USB cable and download Vuescan software ( This works perfectly on LS2000 - Macbook Pro combo.
Jun 02, 2008 | Nikon LS 2000 Film Scanner
Drivers for Nikon LS 1000
I believe that's a SCSI-interface scanner, making its setup more complicated than there's room for here. Here's what Nikon says about SCSI setups: <> and the Nikon software for the LS2000 and LS3000 (but maybe it'll work for the LS1000 too) is at <>. There's a good set of detailed installation instructions under cineman's entry at <>. Good luck!
Feb 11, 2008 | Photography
LS 2000 w/SCSI connection
does the nikon scan sofware recognise the scanner ?
Sep 20, 2007 | Nikon LS 2000 Film Scanner
Nikon LS 2000 Film Scanner Logo
321 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
