Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Delonghi PACL90 fe error light, drained water tubes, only a few drops of water, reset at power plug, error does not go away.
SOURCE: FE Light
You need drain the water and then function normally.
Posted on Oct 02, 2007
  • 9 Answers
SOURCE: Delonghi Pinguino PacL90 replacement hoses
Delonghi Replacement Parts:  800-865-6330
They only open Monday through Friday from 8:30 - 5:00.  Not much help when the unit goes out on a weekend.
Be very familiar with your product before calling.  I dealt with a few incompetent people before I got to someone helpful.
Posted on Jun 08, 2008
  • 121 Answers
SOURCE: solid ice on coils
sounds like the compressor may not be shutting off, that may be the sensor (t-stat) or a freon leak, but usually only a partial part of the coil freezes up if it was low on freon an would not be cooling properly. if under a year old call manufacture. if 2-5 years old may still be under warranty if the repair is a freon issue. if its the sensor your looking at about 40. fot the part and roughly 75-95 for labor (depending were you take it too). check your purchase date and read your warranty 1st
ALL BRANDS APPLIANCE REPAIR
5008 W. LINEBAUGH AVE #8
TAMPA FL. 33624
OFFICE # 813-908-2002
FAX # 813-908-5559
EMAIL customerservice@allbrandsapliancerepair.com
we are a authorized servicer for delonghi if you have any aditional questions thank you
Posted on Jul 11, 2008
SOURCE: Empty wateron DeLonghi Pinguino Pac L 90
That probably is Ft, meaning full tank. Look on the bottom of the back side, and there should be a small "hatch" that will open. The two small hoses in there are drain hoses that can be unplugged to drain the tank. They're right at the bottom, so if you have a way to raise the unit up a little that would let you drain the water into a container. Might be a good time to clean the filter too.
Posted on Sep 19, 2008
SOURCE: My error code E1 won't clear after draining the water resevoir.
I offer the
following procedure to clear the nefarious E1 indication, and obtain
another 720 hours of cooling bliss:
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
If you doubt the veracity of this information, or it does not work as
expected, you can get it directly from the source at:
1-800-237-4277
which is the Sharp customer service line. But, you'll need to call
between 7 AM and 7 PM US Central time, and have your model number and
serial number ready.
Posted on Jul 17, 2010
What does it mean when it doesn't work & it says "fe"?
FE may actually be "FT" which means full tank. Refer to http://web1.dlservice.org/dlservice/dataload/istruzio/GB-5751015400.pdf page 14.
Empty the internal safety tank, through the drain hoses. Refer to Page 16 on how to do that.
May 25, 2010 | DeLonghi Pinguino PACL90 Portable Air...
I have a delogongui air conditioner pacl90 and the air conditioner just is running with only a sign of FE THE REMOTE CONTROL WORK AND THE AIR CONDITIONER TURN ON WITH THE SIGN
According to the manual FE code means the tank is full. Open the cover on the rear of the AC, it is located at the bottom, Pull out the 2 drain hoses, take off the caps and let all the residual water flow out. Place the caps back on and put the hoses back inside.
Aug 12, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Blinking ft what do i do?
According to the manual, blinking Ft and some people think it is blinking FE, Means the internal tank is full. Empty through the drain hoses. Open the cover on the rear of the AC (it is located near the bottom of the unit) Pull out the two drain hoses, remove the caps and let the water flow out. Put caps back on and place hoses back inside.
Jul 06, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Sep 08, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Help please...blinking FE but E does not have top line to the right
Check that the error is not Ft, that means Full Tank.
Drain the internal safety tank through the drain hoses by opening the cover on the rear of the appliance.
there you will find two drain hoses,pull them out, take off the caps, and let all the water flow out.
When finish draining the water place the caps and the hoses back in place.
You also need to clean the filters and let them dry before putting them back in place.
Here is the user manual, see self diagnosis section.
Sep 05, 2008 | DeLonghi Pinguino PACL90 Portable Air...
How do i empty the tank
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, fe shows in the display how do you empty the tank.
This is the user manual site.
scroll down to the diagram on page 16 and they describe how to empty the water from the system
http://www.delonghiusa.com/manuals/PACL90.pdf
To empty the tank on the rear of the
appliance.
When all the water has been drained, place
the caps back on the hoses and put the
hoses back inside.
Clean the filters and dry thoroughly before
putting them back.
Remember to give me a solved rating before you log off!
Thank You Huuum
Aug 12, 2008 | DeLonghi Pinguino PACL90 Portable Air...
PAC L90 water tank capacity
when tank is full you will get the letters FE will signal a FULL TANK
(The tank is full)
You have it setup to constantly drain GOOD.
Should you should not plug the drain hoses to get colder air.
Do let it drain . It is more convenient!
If the unit is the proper BTU for the square footage of the area to be cooled it will be cold!
If the tank gets full you will not get cool air?
Please remember to leave a rating before you go!
Thank you
Jul 28, 2008 | DeLonghi Pinguino PACL90 Portable Air...
It stopped last evening and is flashing what looks like FE
Your water tank is full. Unplug upper and lower hoses, empty into jar and throw away water. RePlug and good to go...
Jul 12, 2008 | DeLonghi Pinguino PACL90 Portable Air...
FE Light
Sep 23, 2007 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi PAC L90
The probe is located on under the main board low inside the only silver metallic box on the bottom w circuit board under it.Remove cover and immediatly you see a 4 inch black wire connected to the main board tucked under and mounted.Unplug the white connector from board, power on, then carefully plug the white connector back on, turn unit off and back on, you should see all 3 mode lights now on steady , no pf error and it doesnt turn off,and you can change modes and temps.Took an hour to take it part and dig around, mine works fookin great now.
Jun 20, 2007 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
277 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
