My laptop is not recognising my microphone. The mixer does not even have a ''mute/unmute'' option and the volume control my mic isnt even there. in my sound/audio devices, for voice recording the advanced options are greyed out. I was trying to use skype and doing a sound test cannot hear myself.
  • 81 Answers
Make sure the mic jack is not in the speaker jack please try swap it. if it does not work, plug the mic and go to control panel select sound devices there u can set ur mic, if not reinstall ur sound driver, thanks, dont forget to vote me if it works
Posted on Jul 18, 2009
Mic not working
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
Feb 07, 2011 | Milwaukee Tool Case Heat Gun
The mic is on because I hear feedback, like a high pitched shrill when I turn the volume of the computer up... even when there's no music playing. How should I take care of this problem?
hi,
in the bottom right hand corner, there should be an icon that looks like a speaker. left click it and display the "mixer" style control panel. When opened there should be a series of faders (sliders) with titles either above or below each fader. Click on the box that says "mute". Your microphone should now be muted and the feedback problem cured. Don't forget to unmute the mic again if you use it.
Jan 16, 2011 | Toshiba Audio Players & Recorders
Got an acer aspire 5517 and the build in mic is not working how do i fix this?
All I can think of is maybe it's muted? Anyway, Go to, control panel>sounds devices> goto the, Mic tab and then "enable" it.
if using windows xp or higher then you can see it ...in your Taskbar... and also goto "Sound Device" & from there, find "Mic" tab & uncheck the "Mute" button or raise the volume etc ...
Feb 07, 2010 | Computers & Internet
Internal microphone - compaq presario c762nr notebook not working
the steps u can try is
1. go to start->control panel->sound and audio devices->double click on it and then go to the voice tab->in the voice tab click on to volume button and click on to the options tab and then go to properties and after that in the mixer device select the first option or check the recordings options then check all of the options in the list then click ok you will get a new window which give you the option of unmuting the microphone.
Oct 29, 2009 | HP Compaq Presario v3000z Notebook
So basically, i tried webcamming my friend thats in Germany, and she couldnt hear me, and i tried testing on my skype test call thing, and they said that my microphone on my laptop might be muted. I have...
go to Tools => Options => Audio Settings, see Microphone Volume, uncheck Automatically adjust microphone settings, adjust volume manually, test mic if green line showing up. To check if mic is muted, when calling contact in the calling window point on mic if it says Unmute microphone click on it, if it says Mute microphone it's already unmuted.
Oct 21, 2009 | HP Mini 1000 Notebook
Microphone not working
check for recording mixer through your volume icon
line in will be muted unmute it
You should find it in the recording option from the mixer
Sep 27, 2009 | ASUS P5GL-MX Motherboard
I plugged a mic to my dell laptop but it isnt working, do i need a sound card?
No, if you have a jack to plug the mic into you have a soundcard. However the mic is probably muted in the mixer software. Go to the control panel, left click on sounds and audio, then click on the advanced button; this should open the mixer in the play back mode, at the top left of the mixer go to options and select properties, a new page will come up with a radio button showing playback or recording, switch the radio button to the recording list and check everything in the checkboxes including the mic and press ok. A new mixer should come up with your recording deviced, from here you can set your microphone device volume.
Jul 01, 2009 | Computers & Internet
My microphone is muted how can i unmute it
Go to start then control panel you should see a tab called hardware and sound click on it and you should find your microphone there and you can unmute it from there. Hope this helps you
Jan 16, 2009 | Skype IM
Hi i have an hp pavilion dv2000 lap top, i am trying to record my acoustic guitar into the comp. This lap has conexant high definition audio sound card inbuilt. However when i try and plug a microphone...
The mic may be muted on the computer. In XP, double click the volume control icon in the bottom right of the screen to get the mixer. If you don't see the microphone input, go to 'options' then 'properties' and place a check in the box to show it. Then make sure it is unmuted and the volume is up.
In Vista, right-click the volume icon and choose recording devices and make sure it is on and volume up.
Apr 23, 2008 | Computers & Internet
Microphone always muted
Make sure you don't have a program that auto mutes your mic. Possibilities are audio mixers, live messenger, etc.
Jan 12, 2008 | Intel D945GTP Motherboard
Computers & Internet Logo
282 people viewed this question
David Payne
David Payne
