Question about Emerson Car Audio & Video
Video/audio cables do not work
Can you tell me where to purchase new video/audio cables for my Emerson PDE-2725N portable DVD player
2 Suggested Answers
Ap12
  • 107 Answers
SOURCE: Emerson PDE-2725N DVD player
My PDE 2625n worked on the way to Mimi's and starting on the way home it displayed "Disk Loading..." then errord out with "Bad Disk". I dug through the internet and over 3 days found the answer.
Your laser is tired. Since the DVD player is cheap, replacing it is not worth the $$. Fix it! Remove the back cover (about 10 small phillips screws). It is important to know that their is a back plate AND a back panel; remove the PLATE which should have a model number sticker.
Now you should see a circut board with a set of polished rails which holds the read head. On the read head (by a ribbon cable ) are two very, very, very small flat blade POT screws. These control the amount of power sent to the laser. Turn the right most one CLOCKWISE about a 1/8 to 1/4 turn.
You can test your handy work by popping in a DVD while the cover is off and seeing if it loads. If all is ok, put it back together. If not turn it a little more. I used a car battery charger to run my test since it's about 25 degrees outside.
Be aware the more power sent to the laser, the faster it burns out (according to my research). By feeling is the DVD player is broke, so what? Am I going to break it? What the hell;) and I cranked away.
BTW I just got this fixed this morning. My kids are screaming with joy for DVD's in the car again! I'm thrilled that I don't have to spend $100 or more to replace this unit.
Cheers!
Ap
Posted on Dec 30, 2007
I just bought an L G DP122 DVD player from WalMart--where I purchased my Emerson flat screen TV--and I CANNOT hook up the DVD player to my TV--the DVD will NOT play. My DVD Player has three (3)...
Make sure tv input is set for the slot you plugged the DVD
into.On the tv remote you will find inputs.Just change for the right one.
Most of the time DVD player is working when TV is on channel 2 or 3 .
Mar 02, 2017 | Emerson Televison & Video
Pde-2725n low battery
The battery is starting to die and needs replacement. It can no longer hold and store enough energy to power the player longer like before.
Aug 14, 2009 | Televison & Video
Emerson PDE 2717
I also needed a new screen to screen power cord. Call 1-866-553-7521 and give them the model # PDE 2717. Ask specifically for the screen to screen power cord because the first cord the see when they do a look-up is the car to screen cord. The cost was $6.00 but adding in shipping brought the total to $15.99. Expect the delivery in 7 to 10 business days. Thanks and enjoy!
Apr 04, 2008 | Car Audio & Video
I have emerson portable DVD I played only twice since I bought it
I had the same problem and the slide part of the player some how got moved and it wouldn't play so I took it and moved it all the way to one side and back and then it worked fine.
Mar 26, 2008 | Emerson MBOX700 Portable Headrest Monitor...
Emerson PDE-2717 portable DVD won't read disc
i believe it is related to power as this issue started on one of these after turning on both screens. i am still dealing with millenium 3000 over a purchase of the same unit. i am going to be trying a 4th unit 'when new stock arrives' but i doubt it.
Jan 15, 2008 | Televison & Video
Video/Tv output cable
http://www.1800customersupport.com/products.aspx?type=pa&view=81&p=71&sc=5
That page will give you all of the accessories for this dvd player.
Nov 26, 2007 | kawasaki PVS-10921 Portable DVD Player
Cheers!
Ap
Nov 16, 2007 | Car Audio & Video
Connecting to front inputs of a Toshiba tv
As a replacement for "Dolby Digital DT3 AV cable" can be used a " 3.5mm (mono) to RCA(or coaxal)" Cable.
Just make sure that DVD Player set for "SPDIF/RAW" or "SPDIF/PCM" output
Oct 12, 2007 | GPX PDL805 Portable DVD Player
Emerson PDE-2717 Portable DVD Player - worked great for a few months but now just says 'Bad Disc' even when using discs that work in other players.
I had same problem, took the back cover off. two scews that are right were the ribbon connects to the read head I believe are potentiometers adjusted with eyeglass screw driver a couple attempts it worked. I also disconnected the plug for external battery and left unpluged since I don't use battery
Sep 18, 2007 | Audiovox D1812 Portable DVD Player
Open Questions:
What is a good lock radio to get these days? I got this thing a couple of days ago to replace an older model with pretty much the same features auto set, dual alarms, that had started to randomly reset the time zones - not good for making it to work... I noticed that it had been updated and the control redesigned, so there were some more bells and whistles. Big mistake - HUGE! The instructions were too small to read, so found the manual on-line, enlarged it to 200%, which I could then see, but it wasn't written in any kind of logical order. Altogether completely and unnecessarily counter-intuitive and complicated. Took me HOURS to set up, and I'm no dummy. I have to go back to the instructions just to change the alarm or even change a radio station. Back it goes. So now I'm trying to find a suitable replacement - auto set and dual alarms are required, and it would be nice to have digital tuning instead of a dial. Don't want or need projection, a weather report, presets, a usb port, or an iPod charging station. There are some units out there that seemed ok, and were well-reviewed, but all the negative comments were about the directions, difficulty of set-up, multiple-function, unmarked buttons that needed to be pushed in particular combinations to get anything to work, and the complexity of changing settings. Sorry for the long rant, but I've been searching all day, and the 5 - 10 top-rated models all have this same issue! Any suggestions or solutions out there that don't cost $300+, or are only to be found used on ebay? Many thanks for your help! Marianne
Feb 28, 2017 | Emerson SmartSet Dual Alarm AM/FM Clock...
Car Audio & Video Logo
50 people viewed this question
Top Emerson Car Audio & Video Experts
xxxxxx xxx
Are you an Emerson Car Audio and Video Expert? Answer questions, earn points and help others
