Question about Hitachi 50UX57B 50" Rear Projection Television
My hitachi lost sounds is there a way to get sound from the cable box and receiver using radio speakers
  • 668 Answers
Most Cable Boxes have a audio out out via RCA connections. You should be able to run a Audio Cable from them to the AUX input of you receiver and get a better quality sound.
Hope this helps,
Skyassoc
Posted on Jul 18, 2009
No sound coming out of speakers tuner or cat/tv
Please add details of setup so I can help you. For example. My Directv box hooks into my HDTV HDMI. Sound is carried inside that cable. I then get sound on my TV from my Directv RCVR without any other hookup. But I do have more. I use an optical cable to go into my Denon 1312 TV/optical input. Since my Wii, PS3, VCR, and formerly Xbox360 all plug into the HDTV inputs and I use it to switch. The Denon is not HDMI capable so this is best for me.
This is the first thing I would try. hook the HDMI to your HDTV from the CATV/SAT box and turn up the sound on the TV. [Box and TV on and correct input used] If you hear audio, the hook it back up as before. Now, turn on the Denon to radio. and turn it up. Got sound?
NO: check speakers and speaker setting. Let's say you have speakers hooked to A but not B. is the selector on B or AB. That won't work. It has to match the hookup. If speakers are on A only, select A only, etc. Also check with known good speakers. Also check all cables to be plugged into the correct spot and plugged in fully.
Thanks PM me if you need more help.
Aug 07, 2014 | Denon AVR-1601 Receiver
How to connect receiver to TV for sound
Does the TV have an audio ear phone jack? if it does get an audio jack that fits the TV Audio out Phone plug. Then connect it to an Audio Amplifier that would run the speakers.
This is one way...or you can solder onto the speaker weirs and run that to the audio amp that is connected to the wall spekers.
Feb 03, 2014 | Audio Players & Recorders
Hitachi 51F710E has no sound
The audio portion of the main board is failing. You can get a replacement here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 07, 2017 | Hitachi 51F710 Rear Projection Television
My Hitachi 43fwx20b has no sound
Sounds (pardon the pun) like a audio circuit problem which is very rare in this set.
Check a few things--if using a cable box hook cable direct to set to rule the box out.
Also if you have a DVD player do you get sound that way?
Last and least likely in this case is in the menu for the set is there an option for the speakers to be turned off?
Failing all these--set has an audio problem and although a very good set may be too old and too expensive to fix for this problem.
It is POSSIBLE also that a surround sound unit could be purchased and with a cable box with audio outputs on back installed and BYPASS THIS PROBLEM--BOX WOULD PROVIDE AUDIO TO THE SURROUND SYSTEM AND IT WOULD HAVE ITS OWN SPEAKERS AND AUDIO CIRCUIT.
Apr 05, 2012 | Hitachi 43FWX20B 43" Rear Projection...
I have a Denon AVR-1707 with a center, 2 front speakers, and surround sound back speakers. When set to FM radio, all speakers work. When set to TV, only one side speaker works. Any ideas? It worked fine...
Follow the sound back to its source. FM is internal so it can't possibly have a cabling issue.
I imagine your TV sound ultimately originates from a cable box which has a nice juicy digital output that the Denon could use. Why route audio through a TV, like the manuals tell you, when you can get it straight to the best audio device without a detour to a TV and its dubious audio electronics?
Apr 17, 2011 | Denon AVR-1707 Receiver
Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Jun 02, 2009 | Samsung HTP-1200 System
Using surround sound
Good Day;
Connect HDMI cable to TV then audio cable back to "SS".
Good Luck, big IRISH.
Dec 15, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
