ROLL THE MANUAL LEVER BACK AND FORTH WITH CONTROLLED FORCE till the needle comes out! the jamming is caused by threads tangled inside the bobbin area. rolled it with a controlled force back and forth. when the needle comes out flip your machine to where you could open the bottom part and remove/clean the threads tangled on the bobbin!
place some OIL.
SOURCE: needle jam
stuck the whole machine the needle did not move .needle and wheel handle both are stuck
SOURCE: Brother CS-6000 Sewing Machine - Jam
I had the same problem.. I think the bobbin used in this machine is no good I replaced mine.. It cost alot too.. but now I do not have any problems.. good luck
SOURCE: machine jammed wheel will not turn needle will not move
Thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands
SOURCE: hi i just brought my machine and it has been
did you turn the machine off and unpluged it for awhile...locking up may be a safety feature to protect machine from further damage
Make sure to remove broken needle if possible and turn lever by hand after restarting machine
