Question about Troy-Bilt Pony Garden Tiller
Have a Sears Tecumseh tiller#(143265122)and havereplaced the whole carborator. Need to know how to hook-up the spring &wires to the governor arm. Need to have a diagram of the carborator. Which way is up for th O ring? e-mail is =beahanback@gmail.com
3 Suggested Answers
SOURCE: what do elect.start wires hook to on 80s 5 horse
maybe there are for the Switch? to the solenoid, that engages the contacts to switch through to the starter. Usually it goes from the battery, to a solenoid, that breaks the Power to - from the battery to the actual "Starter motor". try to "Trace" them out and see where they go. just a thought?
Posted on Mar 07, 2010
  • 13 Answers
SOURCE: Troy bilt bronco
clean and lube around butterfly arm and "windvane' under engine cover.most governors are controled by air coming off finns on flywheel also check to see if you have return spring broken or missing
Posted on Mar 27, 2010
Governor linkage need to see cannot get it set
Check out CHAPTER 4 GOVERNORS AND LINKAGE it shows the different governor systems used on Tecumseh engines.
http://www.barrettsmallengine.com/manual/tecumsehlheadmanual.pdf
Feb 06, 2016 | Tecumseh Snowblower Snow Blower Starter...
How to adjust governor on a Tecumseh hmsk80?
Static Governor Adjust.
With the engine stopped, loosen the screw holding the
governor clamp on the governor lever. Rotate the clamp in
a direction that will force the throttle shaft open and allow
the governor follower arm to rest on the governor spool.
Push the governor lever connected to the throttle to the
wide open throttle position. Hold the lever and clamp in
this position while tightening the screw.
Feb 27, 2015 | Tecumseh Garden
Engine speed surges up and down
Keith:
First check for the obvious... fresh fuel? clean air filter? carburetor mounting bolts/nuts tight? cylinder head bolts tight? crank case bolts/nuts tight?
Now to adjust the governor:
Find where the governor shaft comes out of the engine... loosen the nut and bolt on the governor arm clamp (where the governor arm clamps to the governor shaft). Gently pull the governor arm back until it stops, Gently turn the governor shaft the same way (some have a slot for a screwdriver or a hex-head for a nut driver to hold the shaft at it's closed position) as you pull the governor arm. Both the arm and the shaft must be at their full stop of travel while you tighten the governor arm clamp. It may take another person to lend a hand to keep the governor arm at the closed position while you tighten the clamp.
Nov 30, 2013 | Tecumseh Snowblower Snow Blower Starter...
I need to know how to adjust the governor on my MTD model 31A-62EE729 snowblower with a 179cc motor
lossen the nut on the governor shaft, and move the arm toward the carb while holding the arm in this position turn the shaft counter clock wise and tighten the nut. and you are done. GOOD LUCK
Sep 03, 2013 | Tecumseh Snowblower Snow Blower Starter...
Troy bilt bronco model # 12180starts & idles fine. How do you set or fixthe governor . It runs at idle speed all the time. I can force the governor open and it with run fine until I turn loose of the...
Mar 25, 2010 | Troy-Bilt Pony Garden Tiller
Have hooked spring at throttle to govenor but now seems to stiff. did i get it hooked to the wrong place? it's on a maxim tiller 5 hp briggs 130202 3131-01
on a b/s 5hp the small governor spring goes on a thing that has two ears in it.take the tank back off and as you bring it back in place you will take the gov. spring and turn the top part of it sideways to slip over the ears of the spring holder.when you have it on the spring should be below the holder with the top of the spring in a groove that is between the ears.make sure the white kill wire is out of the way of the throttle cam.this should have the governor spring on correctly.
Mar 16, 2010 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I have a 9hp Tecumseh engine on my Sears chipper vac. I rebuilt the carb and forgot how the governor and throttle linkage hooks up. Could you send me a diagram showing what holes these linkages go in? The...
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Oct 21, 2009 | Craftsman 6.5 Hp Chipper Vac
Engine reves full out can not controll. It's a 12 hp tecumseh.
check that the governor spring is properly attached and that the cable is not stuck
Jun 13, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Displaced carborator spring-mower starts but immediately chokes off
Connect the spring to governor arm. It should be very lose
Jim
May 30, 2009 | Craftsman Garden
Troy-Bilt Pony Garden Tiller Logo
195 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
