Question about Brother MFC-440CN InkJet Printer
I test ink and clean it at list 10 times change the blue I get abot 30% blue on the test. Can you help? AM
  • 21 Answers
Had the printer sat for a long period of time since it's last use prior to having the problem? If so the ink may have dried up in the feed from the cartridge. If this is the case remove the cartridge and try cleaning where the ink feeds with a Q-tip and some rubbing alchohol.
Posted on Jul 18, 2009
Why blue lines when document printing?
You need to do a head clean you should be able to find this in maintenance section of the printer program.
They get a little dry spots or dirt on the cartridge.
This is a ink eater so uses a heap of ink could take 2-3 head cleans to clean it.
Regards Craig
Feb 11, 2018 | Office Equipment & Supplies
Blue color doesnt print
bip your print head in hot water for about 5 to 10 seconds. put it back into the printer without drying it. start printing immediately.
Jun 24, 2012 | Kodak ESP 5 Printer
I bought a use epson 1400 ....it sat around for a lil bit ....when i went to use it some of the inks were out....so i replaced all 6 inks...was running the cleam mode...probly 20-30 times...every time the...
Go on line and buy yourself a cleaning kit for the machine, that contains solvents to remove dried ink from the bubble jets.
Using the cartridges to clean the machine is a waste of time
A UK site is www.choicestationary.com.uk this site lists all kits available for Epson machines
Aug 23, 2009 | Epson Stylus 1400 InkJet Photo Printer
Blue (CYAN) not printing despite changing ink tank
enough ink b ut not printing at all - blank paper on every time despite noise as if printing
Aug 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Jan 13, 2009 | Canon I960 InkJet Photo Printer
Changed all ink cartridges, now only black and blue print
Sounds like your printhead is clogged. Since it isn't removable on this printer the following is a last ditch somewhat messy possible fix.
Here is the procedure that got my CX4600 printer working again:
Symptoms: head cleaning made the test pattern get worse instead of better, until I got no test pattern at all.
1. Unscrew the service panel door on the back of the unit to expose the waste tubes.
2. The direction of flow is "down from the TOP tube, into the plastic elbow, out to the RIGHT tube that goes to the waste repository".
3. Disconnect the plastic elbow from both tubes.
4. Clean the elbow using a paper clip and peroxide until it is completely unclogged and clean.
5. Get a waste receptacle, such as a small cup or something to catch the ink, and place it under the TOP tube. You will probably have to aim the tube with your fingers or a pair of pliers into the cup. The waste is going to spray out, possibly spatter if the waste has become hardened in the tube, so make sure you're doing this somewhere that you can clean up easily.
6. With the waste tube aimed at the cup, hold down the "ink" button on the printer until the cleaning sequence starts. The sequence will take about 20 seconds and blow the tube out in spurts.
7. If stubborn, you can loosen the junk in the tube using some peroxide - it doesn't take more than a drop from the end of a q-tip to start eating away... give it a few seconds to work itself upwards into the tube. Massage the peroxide up the tube with your fingers for more effectiveness.
8. Run the cleaning cycle one or two times to make sure that there is either air or nice wet ink coming out, but no more solid waste.
9. Reassemble
10. Connect CX4600 back to your printer, and print a test pattern... perhaps one more cleaning... should be fine.
Also see this website:
http://www.fixyourownprinter.com/forums/inkjet/23861
Jan 09, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Changed cartidges & now black and blue don't print on C88+
Try to remove and reinstall the blue and black cartridge and check if you punctured the plastic cap underneath the cartridge itself. then reinstall it and make sure you hear a click or it snaps in. try head cleaning cycle from the utility and print a nozzle check pattern. If same output maybe carts are bad. If that is a genuine epson ink cartridge, call epson and have the ink cartridges replace since they are new ones and for sure epson will send inks since you just bought it. make sure you have date of purchase handy.
pls dont 4get to rate solution if it helps... thanks!!
Apr 16, 2008 | Epson Stylus C88 InkJet Photo Printer
Change all ink problem
1- powering off the printer and leaving it for 30 sec. then powering back on... test
2- power off, open the cage, move cartridge caddy to center to remove cartridges... clean cartridges nozzles with a damp cloth, clean cartridge connectors as well as cart caddy connectors with a soft cloth.. no water. re test by replacing the cartridges and powering on the printer.
if the operator still has the message. power of, try with 1 cartridge at a time, turn on printer and try to COPY any document...
if all of that is still failing, then as the Lexmark rep told me, i'm sorry for any inconvenience this brings you, you have a defective printer.
Mar 11, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
Brother MFC-440CN InkJet Printer Logo
59 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
