My washer will not spin, it agitates pumps the water out but will not spin. I checked underneath with a flashlight, when in the spin cycle the motor is turning and the drum is not.
  • 5 more comments
  • harry_nelson Jul 18, 2009
    It is an Amana top load washer model NTW5700TQ, it is about 2 years old.
    Was the pump on the side of the motor next to the front panel? Yes
    When you have the washer in spin cycle, did the motor run but no spin? The motor runs and spins(You can see a silver part just above the gear box turning), only the drum does not spin.
    No I do not have an extended warranty. Do you have a schematic and part number for the spin basket drive assembly?
    Thanks, but I do not see the picture.
    In response to your question below there is a gap wide enough to put my hand under the agitator. I removed the agitator and did not see a drive block. Do you have a diagram showing the drive block? and part number? I think this is where my problem is.
    - One other thought, Check and see what the gap is between the agitator bottom edge and the tub. There should only be enough gap to put the tip of your finger under it. Sometimes the drive block will grind down and let the inner tub fall so it can't spin. If you remove the agitator, you can see the drive block.
    Thanks the drive block seems to be the problem. Do you have the part number for the drive block and a suggestion on where to purchase it?
    Yes the solution was very helpful
    President:
  • 1,136 Answers
Hi, Can you please let em know the make/model # so I can look this unit up. I understand it agitates but does not spin? It sounds like it could be a spin basket drive if the motor runs but no spin. Is it a whilpool made washer.
I will wait for the odel #. Please let me know if there is addition info on tis matter.
Vic
Posted on Jul 18, 2009
  • 10 more comments
  • Victor
    Victor Jul 18, 2009
    The model # I found is a whirlpool made washer. When you looked underneith the washer, Was the pump on the side of the motor next to the front panel?
    When you have the wsher in spin cycle, did the motor run but no spin?
    Vic
  • Victor
    Victor Jul 18, 2009
    Thank you for this info. It narrows things down to the spin basket drive assemble. I have seen so many of these newer washers with this issue. It is a costly repair. Is there a chance you have the extended warranty?
  • Victor
    Victor Jul 18, 2009
    The cost of the part is around $174.00.
  • Victor
    Victor Jul 18, 2009
    Here is a picture of the basket drive assembly. The basket drive is #1 in this picture and the part #3360629. I am in the proccess of typing up instructions. As soon as I finish, I will send them to you.
    Vic
  • Victor
    Victor Jul 18, 2009
    I am sorry...... here it is
  • Victor
    Victor Jul 18, 2009
  • Victor
    Victor Jul 18, 2009
    Instructions on getting to the basket drive assembly
    Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them. Now the cabinet will lift off the frame and you can set it aside.
    Now you will need to remove the agitator by removing the agitator cap and then removing the 7/16” bolt in the top of the agitator. Remove the white top splash ring on the outer tub. Remove the spanner nut located on the inner tub post that the transmission shaft runs through. The spanner nut is a standard thread and turns counter clockwise to remove. After the spanner nut is off, remove the inner tub and remove the drive block that the inner tub sits on, off of the post.
    How to remove a spin basket drive:
    Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you will need to unplug the capacitor.
    Now you will need to remove the transmission. Once the transmission is out of the way, locate the basket drive cam (white) in the brake housing under the tub and while turning it clockwise, pull down and the basket drive will release and come out.
    The new basket drive comes with hardware/springs. Make sure to use the same color spring. While pushing the new basket drive into the brake housing, be sure and turn it.
    Put the transmission back in and reinstall the motor. Put the clips that hold the motor in place and plug in the harnesses.
    Put the pump back on and the clips to hold it in place. Put the drive block on the post and be sure the tabs on the post fit inside the slots on the drive block. Set the inner tub on the block. Tighten the spanner nut down and put the splash ring back on the outer tub. Put the agitator back in.
    Set the cabinet back on the frame. Make sure the lip on the front cabinet is under the front rail of the frame. Ease the cabinet on the frame making sure the two rear sides of the cabinet set down on the tabs of the frame.
    Put the two clips back on that hold the cabinet and plug the lid switch back in. Fasten the control panel down and you are all set.
    I know this is a lot of information. I hope it helps you out so that you can get this problem taken care of.
    After reading through this, please let me know if I need to clarify anything for you.
    Vic
  • Victor
    Victor Jul 18, 2009
    Sorry for the delay, had to go for the night. Let me get you a picture of the block
  • Victor
    Victor Jul 18, 2009
    Again sorry for the delay, The drive block is in the picture with the tub and is #22. With the agitator out, you will see the top of the block and it should be flush with the top of the post. When I keep saying post, this is actually the top of the spin basket drive shaft. There are 2 tabs on the top of the shaft and the block locks down on that shaft.
  • Victor
    Victor Jul 18, 2009
    Sometimes the block the grind down and slip down on the basket drive shaft.
  • Victor
    Victor Jul 18, 2009
    Part # 389104 for the block. I believe this is the problem as well. You will need to remove the cabinet and the inner tub to change this. Here is the instructions for removing the cabinet.
    Remove the white splash ring locked on the outer tub. Remove the spanner nut that hols the inner tub to the block. Remove the old block and install the new block making sure the block slides over the tabbs on the basket drive shaft.
    Please let me know how things go.
    Thanks
    Vic
  • Victor
    Victor Jul 18, 2009
    You can purchase it at a local appliance parts store or, online at www.repairclinic.com
    I am glad you found the problem
    Vic
Washer wont pump water unless in spin cycle
it is not supposed to pump water unless it is in the spin cycle. On most topload washers the motor turns one way for the agitate cycle and then the motor reverses during the spin/rinse cycle which in turn reverses the pump and causes it to pump the water out.
Oct 28, 2010 | Maytag PAV5157A Top Load Washer
Water leaks under washing machine
SOUNDS LIKE YOU MIGHT HAVE A WORN OUT DRAIN PUMP, YOU WILL HAVE TO OPEN IT TO DO A VISUAL CHECK ON IT,
Feb 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer fills with water but then nothing, put on spin cycle water empties. The agitator does nothing
the agitator is not on properly due to worn parts under it. remove the top cap, then use needlenose to remove the cap underneath it. lift up from very bottom of agitator. look for worn areas
Oct 07, 2009 | General Electric WHDSR209DWW Top Load...
Full of water, won't drain past the agitation stage, just goes dead
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
May 04, 2009 | Washing Machines
Water pumps in timer cycles but machine will not agitate or spin
Hii!! yo check your washer belt.if on the you have a tranny problem.good luck
Jan 16, 2009 | Frigidaire FWS833A Top Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer 24622300. clothes are very wet after spin cycle
washer may not be spining at all start in rinse cycle allow washer to wash and advance through cycle on it's own do not advance manually..after agitation listen for short pause after pause pump out should begin after pump out should be another short pause then spin should start..if spin does not start after 2nd pause suspect transmission if lid is raised spin may start but if it doesn't start during normal operation bad gearcase one other ck possible look underneath for oil it may be getting on clutch causing clutch to slip and not allow to spin full speed
Nov 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer problems
this part underneath is the direct drive 3 dollars most washer part stores easy to install this is what had broken and it clicking underneath
May 29, 2008 | Washing Machines
Washer leaking water from bottom
You may want to check the seal at the bottom of the agitator, there is a o-ring that keeps the water in the drum from leaking through the agitator as it spins. This is a cheap seal and will wear over a period of time from exposure to bleach and detergent. You need to take the agitator apart and remove it from the drum and you should see this seal at the base of the agitator were it meets the drum.
Replace the seal and reassemble, take the metal casing off the washer and fill the drum with a little water, wait, and see if the water is leaking under the drum. If no leak, try to reassemble and run the washer. If is still leaks then check http://www.applianceaid.com/genew.html
Yours Truly,
Mr.Fix-it-guy
Jul 30, 2006 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
