Air vents switch to defrost on hill climb - Heating & Cooling
  • 1 more comment
  • ccecliff Jul 19, 2009
    Already spent $98 to have 95 Lincoln Towncar checked out - no prob with check valve, or vacuum. They wanted to pull entire dash, to see if dirty or something - Wanted $1100. Any other suggestions?
  • ccecliff Jul 20, 2009
    Re vacuum line feed - No, haven't - trusted auto dealer that it was ok - I don't know where it is located. Just not willing to spend 1100 dollars on a car, that will retail for about that. If you can tell me how to locate, I'll try for sure (I never totally trust "parts replacers") Appreciate your come back tx
    Best Ive heard so far - will try this, thanks
  • 6,674 Answers
Vacuum leak or faulty check valve in line to AC controls. What make , model , year , of vehicle?
Posted on Jul 18, 2009
  • 1 more comment
  • Mike Butler
    Mike Butler Jul 19, 2009
    Have you tried locating vacuum line feed yourself to dash controls?
  • Mike Butler
    Mike Butler Jul 20, 2009
    Normally you'll find a vacuum line connected to brake booster perhaps, that connects near bigger vacuum hose on booster, or in earlier years came right off intake manifold, but probably easiest thing to do is look at firewall area on drivers side, or mid way across, for a small black, usually hard plastic or rubber hose going into firewall that would be going to area of heater controls. If control panel not too hard to get out of dash, you can usually pull it out far enough to see or locate vacuum line coming in to back of controls. See if you can find anything & in the meantime, I'll see if I can get some more info on your particular vehicle & where it might be. Also, if you look under dash on passenger side to middle while you have engine running, and switch back & forth from & to defrost, you may hear where all that is going on, and find line in that area as well.
  • Mike Butler
    Many vehicles including Lincolns, incorporate a fail-safe system so that if there is a drop in vacuum due to slight or large leak in system or any circuits (hoses) used, it will automatically go to defrost, in order to allow for clear windshield for driving. Yours would be the same, and from what I can find, it doesn't appear too difficult to pop front trim panel off around controls & remove screws to get access to rear of controls. Sharpen your hearing & listen for a small "hiss" anywhere under dash, behind controls etc, and you may just find it yourself. I purchased a vacuum gauge years ago, that I use, and I would put it in line coming to controls (main feed line in) and shut engine off & see if vacuum held, if it did, i knew up to controls was good, so my problem was either a leak at control itself, or one of the outgoing lines from control.
It runs good on flat but wont climb hills
If it is a high mileage engine, it will likely never climb hills again. Greater torque and horsepower are required for hill climbing, and the more worn an engine becomes, the less torque and horsepower will be available.
May 06, 2015 | Motorcycles
1995 S-10, when going uphill or accelerating my AC blows out the defrosters when backing off it comes out the vents again
It is almost certainly due the drop in manifold vacuum when climbing hills or accelerating. Back in my youth windshield wipers stopped when you stepped on the gas.
Sep 08, 2014 | Cars & Trucks
Why does my ac switch from vent to defrost while driving?
This is due to a vacuum issue. The vacuum created by the motor is used to operate the actuators that control the direction of the air flow. When you accelerate you are creating more vacuum which in turn creates more in the actuators causing them to pull harder so therefore the desired setting is changed. Check your Pcv valve and make sure your hoses aren't dry rotted or leaking elsewhere, which may impact overall vehicle performance. Hope this help explain what's going on
Jul 19, 2014 | 1997 Jeep Cherokee Country
I have a 1995 dodge ram 1500 4x4 with a 5.2 l automatic. There is vacuum line sticking up behind the the engine with a vacuum brake hooked to it. where does that go
Not certain... just a thought... I believe Dodge uses vacuum solenoids to switch air flow from floor to vents and to defrost. Perhaps your loose line is from that solenoid. My '93 would go from defrost to floor when climbing a hill because of loss of vacuum. I hope this helps steer you to a solution.
Mar 23, 2014 | 1996 Dodge Ram 1500 Club Cab
Why is the AC blowing air through the defrost vents in the dashboard when going up the hill
Because your go higher which is colder air which make your air vents colder
Dec 07, 2013 | 2003 Ford Explorer Sport Trac
1988 mighty max won't climb hills with air filter
you need new air filter old filter clogged.
Apr 01, 2013 | Cars & Trucks
My air condition changers when you pull up hill it changer from the lower vents to the defrost vent
You don't indicate what year or model Ford you have but it sounds like you have a vacuum controlled system. When you climb a hill engine vacuum drops and the HVAC defaults to the defroster vents. If your system has a vacuum reservoir it may be leaking. If it doesn't you can add one. Older Fords used a metal can about the size of a quart. Older GM cars used a round plastic one. You might be able to find a used on. They are easy to install. Just cut the vacuum line going to the HVAC system. Install a "T". Connect the 3rd nipple on the "T" to the reservoir and you should be good to go.
Apr 17, 2011 | Ford Explorer Sport Cars & Trucks
When a/c is running why would air stop comming through vent and go through defrost?
The panels (or flaps, if you prefer) that are used to direct the air to the windshield, the panel, or the floor are operated by engine vacuum to be moved one way, and spring tension to move the other. When you step on the gas to climb a hill, or move out from a stop, the vacuum goes away (it is generated by the engine trying to get air, and the closed throttle preventing it from doing so), and the panels are moved into their rest position by the springs. So the air direction can change until the vacuum is reestablished to properly configure the ventilation directing panels.
On my Aries K wagon, the air comes out the defrost when I step on the gas.
Jun 15, 2010 | 1997 Chevrolet Blazer
With AC blower set on MAX, if I have to accelerate or climb a hill, the air switches to the defroster vents. Any ideas on what to check?
may possibly be a vacuum leak... look underneath to make sure all the vacuum hoses for the vents are intact. there is a small resevoir (usually mounted on the firewall near the brake booster) it looks like a film cannister or similiar. that may have failed. you should be able to similate that same action by flooring it on a level road. you will hear the vents change as it loses vacuum.
Oct 05, 2009 | 2006 Ford Ranger
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
