Question about Refrigerators
Water dripping within the fridge
I have a fridge, approx 15 yrs old, upper freezer, lower fridge. Automatic ice cube maker in freezer. When I open the fridge portion, I see water dripping from the upper portion (freezer). I do not see any water in the freezer itself. What would be the source of the problem?
    President:
  • 1,136 Answers
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Posted on Jul 18, 2009
What causes my ice maker to drip water?
HI,
This could be either the ice maker is old and the finish inside has depleted, the water valve is going bad or you had a jammed ice cube and now it overfilled. Many different reason this could happen. Does the ice cubes stick together with a bridge? Is the drip coming from the ice maker head unit? How is the ice in the pan its stored in, stuck together? In the pan, has the ice glaciered together? Need more information please. Thanks
Aug 09, 2014 | Kenmore Top Freezer Refrigerator
No water in automatic ice maker, therefore no ice cubes.
Do you get water at the front dispensor, if present? If not check the refrigerator water filter. If you have an RO system feeding filtered water to the fridge, check it's filter. Also there is a solenoid that lets water into the ice cube maker, have a professional check it to make sure its working correctly. Lastly I have had to replace the entire ice cube maker, sometimes they do fail. Replacements can be found fairly easy on the internet.
Feb 21, 2010 | KitchenAid KUIS18NNT 18" Automatic Ice...
Ge monogram fridge over freezer model has stopped making ice
water valve dripping like a faucet and making a big old ice cube in the fill tube? Ice cube hung in the ice maker? bad water filter? A wittle bit of all of the above?
MONOGRAM MANUAL
IM6 notes
Bonus
Jan 12, 2010 | GE Refrigerators
Kenmore 795-75202400 icemaker problem.
Good day,
Either the water valve opens to fill the ice maker cavity, and doesn't shut off soon enough, causing the ice maker to overflow.
Normal file time is approx. 7 seconds.
This is the most common problem.
As well, it is possible the micro switch in the ice-maker that tells the valve to open and close has malfunctioned.
This is all based on the fact that the freezer maintains a normal temperature.
To test the freezer for consistency, place a plastic glass in the freezer half full of water.
Check it in 8 hours. It should be frozen solid. Then place the glass in a plastic bowl, and lay the glass on it's side. Recheck in 24 hours. The ice should remain in the glass.
If not, there is a problem with the refrigeration system.
Nov 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
My jenn air freezer is not making cubes. the
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 13, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
Ice maker freezing up
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Aug 23, 2008 | Whirlpool ED2FHSS Side by Side...
Kenmore Elite 795 75542401
I replaced my "entire" ice cube maker (tube,hoses,water pump, ice maker) and it still pooled water at the bottom. I removed the back panel in the freezer and noticed the ciols go through a defrost cycle and water forms in tray under coils. I removed the lower panel on rear of fridge -and found a drain hose near the water solenoid/pump. I blew compressed air into the hose and hopefully unblocked it so it can drain into the pan not the freezer.
Jul 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Superba ice maker stopped working, door water still dispensing
Use a cup of water and just fill the ice cube maker with enough water for the first batch and the sensor will then begin making ice again.
My ice cube maker stopped working after I changed the filter. After reading countless posts about wiring and defrosting and using a blowdryer into the fill line I emptied my freezer and fridge, then unplugged it. I got no results after two days. I finally just put some water in the ice cube maker (the metal ice cube tray below the white plastic fingers that forms the cubes) plugged it back in and closed the door for a few hours and it worked. I wonder if I needed to defrost the unit at all. It was working before I changed the filter, then the filter was full and stopped water from flowing (or decreased the flow dramatically anyway).
Good Luck
Barry Eager
Apr 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
