Question about Whirlpool Dryers
No heat I have 2 Whirlpool Dryers and neither of them produce heat! After replacing the heating element approx. 1 year ago it stopped again!!! I bought another used Whirlpool Electric Dryer and it worked at the house which I purchased it but stopped almost shortly after I hooked it up :s I was thinking that the Fuse breaker has a short of some sort in it because, after cleaning all the lint traps, etc., I pulled out the breaker containing the fuse [old style yes I know :( ]. I then switched the fuse, which was not blown, and snapped it back into place and the dryer started to run again....BUT with no heat! I have them both running now (thinking it was the breaker holding the fuse (must be thrown)!!! But now the problem is still no heat and I am hoping that I don't have to replace the heating element again because that is the whole reason why I have 2 dryers...because the element would have cost me almost as much as I paid for another, newer, used dryer :( Is there similar problems in these models or do you think that the, possibly, thrown fuse breaker has caused a short is one of the thermostats, fuses, etc.? Please help give me some advice :) The two model numbers are (starting with the older one): (1) Whirlpool model number: YLER5637EQ2 (2) and the newer Whirlpool model number: YLEQ5000KQ1
    President:
  • 1,273 Answers
Try testing the voltage across both fuses. The time you swapped fuses, and the motor ran without heat indicates to me that one of your hot leads is not getting voltage. On a three wire system, you should have two 110v leads and a common. Make sure that the cord is connected properly, and the same for the receptacle that you plug into. Test the receptacle as well for proper voltage and a good common ground.
Hope that this helps. Please repost if necessary.....Operators are standing by......!
Regards, --W/D--
Posted on Jul 18, 2009
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
I have a Whirlpool dryer - Imperial series. The dryer is 5 years old and we have already had to replace the heating element 1 1/2 years ago. Now the dryer seems to get hot but won't dry the clothes. It...
Good day,
Dirt. First step is remove the vent system, and test performance. If that's it, either clean or replace the vent system.
If that is not the problem, remove the lint filter, remove the 2 screws under it. With a screw driver, at each corner of the front of the lid, pry up the lid off the clips and prop up.
Now go to the rear, and remove the back panel. On the left side the air chute housing is held on with screws. Remove the screws and pull the housing out and up as far as possible.
Clean all lint build up in that area especially around the blower wheel. That should solve your problem.
Here's a picture of the back of the machine.
Sep 18, 2010 | Whirlpool Dryers
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
THIN TWIN SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 12, 2010 | Whirlpool WHP1500S Electric Dryer
Our Whirlpool Senseon Dryer stopped heating. It's
I had the same problem. I replaced the thermistor,heating element and another part and still didn't correct problem. i finally had a friend come check it and believe it or not it was the 30 amp fuse in my fuse panel of the house.Come to find out the dryer will run and everything works like it should on 1/2 of the 220 plug but the other half runs the heating element.Both fuses must be good. I replaced the 30 amp round fuse and it works and heats perfect. I hope this helps you and saves you some time and money.
Tommy
Mar 16, 2010 | Whirlpool Dryers
Dryer is not heating
i replace the thermal fuse kit 2 month ago and my dryer was working good but 2 days ago stop heating again so i did replaced the thermal fuse again and i did some lint cleaning but this time it only last about 20 min. and stop heating again.what could be the problem?
Mar 01, 2010 | Whirlpool Inglis IP8200 Dryer
Dryer heating element(s) are inconsistent
there is only 1 element. were you taking these readings with the wires on them?
the other 2 were thermostats.was there lots of lint?
sounds like you may have bad thermostat.
Nov 23, 2008 | Whirlpool GEQ9800P Electric Dryer
3 1/2 year old Whirlpool Duet Dryer stopped heating up
it could be several things but the element could should be the last part i would check first if you are still using fuses change them both if that doesnt work call for service call a good service man stay away from major companies they are expensive i know i worked for most of them
Nov 22, 2007 | Whirlpool GEW9250 Electric Dryer
Blowing heating element
Wow. Doesn't sound normal to me. I have two thoughts going through my head. One is that perhaps the blower fan is bad and not giving it the proper air flow. However the high limit switch should shut off if it gets too hot, which leaves me to believe the thermostat and/ or the high limit switch are bad. Naturally you want to vent the shortest distance possible. Good Luck. I know a good repairman could locate the problem. That's the problem, finding a trustworthy repairman. If you do hold onto him. Good Luck
Oct 07, 2007 | Dryers
Dryers Logo
235 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
