Question about Craftsman 10.5 Hp 33" Commercial Cutting Width Zero Turn Lawn Mower
Craftsman 18.5hp runs a few mintues then cutsoff and will not restart starter turnes over will start with starter fluid but will not take the gas
  • 130 Answers
Rebuild carb
Posted on Jul 18, 2009
Leaf blower craftsman manual
Is it getting gas? Have you tried a spray of Starter Fluid in the Carburetor? to see if it will start on that?
10% Ethanol Gas is a carburetor killer. If the engine hasn't been run in few months, chances are the Ethanol caused problems in the Carb.
Write your congressman and tell then to stop the Bill that has us using this do-nothing Ethanol gas .
Oct 26, 2013 | Garden
My craftsman tractor will not run. seems like it is not getting any gas
you can test this real easy by squirting starter fluid in the intake and trying to start. If it starts and stays running, good-you may or may not have to keep using starter fluid. You might try new spark plug.
If starter fluid does not work, then you have a problem with spark plug, spark plug lead from the coil or a bad coil.
Sep 05, 2013 | Craftsman Garden
Craftsman hand held gas leaf blower will not start. I have put in fresh gas, changed spark plugs, cleaned the gas filter, tested for spart and it does spark, changed the air filter but all this and still...
If it has a spark then try spraying some starter fluid on the air filter. If it attempts to run then the carburator is stopped up. If it doesn't then you most likely have low compression. Remove the spark plug and screw in a compression tester and pull the starter a few times. It has to have no less than 70 psi to fire and run. 90+ would be even better. If it is 50 and below try pouring a little oil in the spark plug hole and repeat the test. If it improves a little then you have a scored cylinder or piston or stuck or broken piston rings. Let me know what you learn and I'd be glad to walk you through some more.
Nov 04, 2010 | Craftsman Garden
Craftsman riding mower clicking noise - wont start
RIDING MOWERE JUST CLICKS AND WON'T START HOWEVER IT WAS RUNNING FIND JUST 5 MIN. BEFORE I TURNED OFF.
May 22, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
It will start then die about ten mintues later and have to restart it and it will do the same thing
Hello. Go to the autoparts store and get one bottle of a fuel additive called seafoam. Add these to your fuel in the recommended amounts. After a few ten minute runs, your problem should be fixed.
Please rate my answer as very helpful. thanks Joe
Apr 25, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 6 HP Craftsman tiller will not run without starting fluid
Carberator is gummed up and will need to be removed and dismantled and soaked in solvent for an hour or two.
Aug 16, 2009 | Craftsman 8.50 Torque Rating Dual...
Chainsaw starts and runs fine for a few minutes
Try fresh fuel making sure oil and gas mixture is correct. Carb might need cleaning and adjustment.
Jul 26, 2009 | Garden
Craftsman 917.270662 starts with starter fluid but won't stay run
the float in the carburator is stuck shut not opening alowing fuel to enter engine
Jun 07, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 10.5 Hp 33" Commercial Cutting Width Zero Turn Lawn Mower Logo
177 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
