Question about Onkyo HT-S680 System
HS-R430 System Have not have this hooked up in a while and can't seem to get it connected and working. I have a DVD player, so I have my cable hookup running into and out of that and then to the TV. I have tried connecting Audio Out from the DVD player to the R430, but did not get any results using the Red, White, and Yellow cable. Also didn't know if the digital input selection might have something to do with it.......... Coax, Opt, or ? Any suggestions would be appreciated. Thanks
  • robbins_b10 Nov 19, 2007
Connect the audio cable (red & white) from DVD player to the Audio DVD in (L/R) of the receiver.
Change the source selector to DVD.
Incase of coaxial o/p from the player, connect it to the coaxial i/p of the receiver. Then select the digital i/p button twice located in the front of the receiver.
Posted on Nov 19, 2007
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
How do i connect my dvd player up to my tv and direct tv?
Hook your coax cable output from sat. to input on tv, then hook your rca cables from dvd output to input on sat. There are several way to hook one up depends on witch hook ups you have , If this don't work or you don't have theese hookups or wann use different hook ups email me at metallica@tds.net
Oct 06, 2009 | Televison & Video
Cannot connect a VCR/DVD player to Zenith SY1959Y
you don't need a code for the vcr/dvd combo to work on your tv. You need to make sure you have hooked up the cables correctly. remember that the dvd can be hooked up with the component cabels and the vhs may need to be hooked up thru the tv cable hookup.
Jan 08, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hook this dvd player to an hdtv
You are confused regarding how to connect your DVD player to your Samsung TV. There is no such thing as "5 composit hookups". Your DVD player most likely has right audio (commonly red), left audio (commonly white), and video (commonly yellow) outputs which should be connected to corresponding inputs on the rear of your TV.
Dec 15, 2017 | GE 5803P Multi-disc DVD Player
Trying to hookup and play standard DVD player
Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
Dec 12, 2008 | RCA F25441 25" TV
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
Trying to Install
Do you have the red, white and yellow hookups on the back of your TV????? If you don't then you need to get an RF Modulator. You can buy one at Walmart. Older TVs don't have the red, white and yellow hookups. You hook up the RF modulator with a short cable to the cable outlet on your TV. Then you plug in your DVD player to the RF modulator. You also plug your cable for the TV into the RF modulator. It really is very simple. Directions are included with the RF modulator. You will need a short piece of cable also.
Feb 04, 2008 | Panasonic DVD-RV41 DVD Player
Magnavox mwd7006 dvd player hookup
if you are useing componet output and the pic is black and white you have them hooked up in the wrong order
The Cableguy
Oct 17, 2007 | Philips Magnavox MWD7006 DVD Player
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
Onkyo HT-S680 System Logo
122 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
