I have a vulcan freeloader 230 gas hot water system. the pilot will not stay lit. and some times when i do get the pilot lit, it will not ignite the main burner until i have lit the pilot a few times.
  • 53 Answers
Clean the pilot assembly if has any orange at the tip. If its burning clean and blue, then its most likely the thermocouple. Safer to get a gasfitter to check it out.
Posted on Jul 18, 2009
Pilot light lit but not igniting to heat water
pilot lit on gas furnace, but the burners won't light (Home ...
answers.angieslist.com > Home > HVAC
Oct 26, 2013 - i have a gas furnace with a lit pilot, but the burners won't light. ... if the thermocouple does not sense the heat of the pilot it prevents the gas controller fromturning on the burners. ... clamped onto the outgoing hot water pipe, if huydronic system) that is telling the furnace it is too hot, whether or not that is true.
Nov 18, 2015 | Water Water Heaters
Can I replace the pilot light on a Vulcan Freeloader 260 gas HWS?
Hello...how old is the unit? Today it is very common for gas appliances to have electric igniters instead of a pilot light. Unless you are familiar with gas controll/regulator valves I would not recommend trying this yourself. I believe it is more likely a faulty or dirty thermo-couple. Again , unless you are familiar with the opperation of gas supplies ,controls ,etc. DO NOT ATTEMP to do this yourself!!! Gas is very dangerous for the less than well informed! Call a service pro or speak to and ask for the assistance of a knowledgable friend.
Feb 14, 2011 | Water Heaters
I have a Vulcan Freeloader that is over 10 years old. The pilot does not stay lit when I release the red button. Also, the pilot flame is orange. What can be done as the main burner would not work when the...
The pilot assembly is stopped up. It will need to be taken apart, blown out or cleaned and re-intalled. The yellow, lazy flame is preventing the thermocouple from getting warm enough to allow the main burner to ignite. Hope this helps.
Jan 20, 2011 | Heating & Cooling
I have a vulcan freeloader 260 gas, how do i make sure it has water in the tank
The old freeloader is feed by cold at the bottom and the hot feed comes out the top. Basically if you are getting hot water out the hot tap (or any water out the hot tap) it has water in it. If you have any concerns post a new fault, I will keep a look out for it. These are great heaters, well worth looking after.
Sep 20, 2010 | Heating & Cooling
My Mum has a Vulcan freeloader 260 gas hot water system and it appears that the pilot light has gone out. The only problem is I can't find where it is to test how to turn it back on. Can someone please...
Remove the access panel lower right hand side and locate the pilot light re-igintion push button. The instructions are pritnted on the back of the access panel.
May 18, 2010 | Water Heaters
Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
Dec 17, 2009 | General Electric GE SmartWater Household...
Running out of hot water with Vulcan Freeloader 300
hi i need help with mi Vulcan 300 hot water main gas pressure...
our kitchen tap got broken and we turn off our main water pressure in front off our house and now our hot water gas not working ....please help
thank you ...
Sep 24, 2009 | Water Heaters
Freeloader 300 pilot light goes out when I turn
make sure that the thermocouple is staying in the flame youmay want to replace it unless it is staing lit on its own until knob is turned if so gas valve bad
May 12, 2009 | Emerson Fans 300 Heating & Cooling...
Vulcan freeloader hot water heater
Could be moisture in the gas supply line - get your gas fitter to purge the line at the meter.
Jul 08, 2008 | Heating & Cooling
Heating & Cooling Logo
756 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
