Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Agitator will not make contact on every turn/hit and miss
Good Evening,
my agitator moves but then does not turn and after a couple of tries makes contact again like a slip and miss gear action.
    President:
  • 1,136 Answers
Hi, The dog kit is bad inside the agitator. Here is how to change them.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Jul 18, 2009
    Brigadier General:
  • 4,088 Answers
Pull the agitator out and inspect the block at the top of the post. It should not be split or the internal splines sheared. If everything looks good, it may have broken a gear inside the transmission. Not a cheap fix.
Good evening, my cd player just stopped working in my expedition. It keeps saying cd error. Even when i try to eject the cd it says the same thing or when i swith cd's. Its a factory 6 cd changer...
I had this happen in my old dodge stratus. My trick to remove cd's was when you stopped or parked the car turn vehicle off and hit the eject button and it will usually eject the disc. remove all discs and then install them again when car is parked and not moving as vibration and bumps while driving can sometimes miss align the disc in the player. Sometimes when the stereo didn't work at all I disconnected the battery and it would reset and work. If this doesn't work it may be broken. Good Luck.
Jul 05, 2011 | 2003 Ford Expedition
Hi, I have a Kenmore 110.26832692, lately it's been making a loud grinding/thumping noise when agitating. The clothes end up wrapped around the agitator, sometimes even stuck underneath it. The basket...
Sounds like maybe the changing of the dogs might be the problem./The top section of your adjatator sould move freely one direction turn it the other way bottom section should move with it. If it does not do that then your dog install got messed up also you should not barely get fingers under botton section of adjatator/ Note the basket is not supposed to move when washing on this unit . see if unit is doing any of those things get back to us...Good luck
Feb 09, 2011 | Kenmore Washing Machines
I have a series 80 top loader Kenmore model 110.92586200 and it does not agitate or spin but pump works and drains water. I took the motor off and the coupling is good. I can move the top part of the...
I'm not sure about this model, but they have agitators (agitating dogs) which grip the agitator and agitates the clothes. It would be best to contact a local repair place and ask , Does your model have them. If it does these are easily replaced and cost about $5. You will have to screw the top of the agitator off, when it's off you can look down into the (shaft) and see a bolt, this will have to be removed and once this is removed the whole agitator will come out. Here you will be able to see aprox.4 plastic pieces with little grippers that may be worn down. These are a simple slide them out to remove and install the new. Good Luck...
Sep 07, 2010 | Washing Machines
Agitator moves freely, but is not engaged in wash cycle
HI. the internal components that make up the agitator should be inspected for damage.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cause this disruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
AGITATOR REMOVAL GUIDE
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to preform a combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytag's may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Dec 11, 2009 | Whirlpool Washing Machines
Agitation doesn't start. First we could do this when just hit the cover or press it, but now it doesn't help.Eugene and Galina
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Whirlpool washer does not agitate/wash but the spin cycle seems to work. I've found that the bottom section of the agitator blades are turning but the top section does not turn. I can also turn the top...
The problem that your washing machine is not agitating, you will need to check certain things.
Please check the timer to see if it is in good working order or not. Next you will need to check the motor and the motor switch. On some of the newer washers the door switch also controls the motor.
If the motor starts running after the washer has filled to the selected level, but the agitator doesn’t move, you will need to check the following parts.
The agitator dogs. They are located inside of the agitator clothes mover. You will need to remove them and check to see if they are in need of been replace.
The clothes mover. This part is the top part of the dual action agitator. Its job is to move the clothes from the top of the spin drum to the bottom part of the agitator.
You will also have to check the inside of the clothes mover to make sure that the gear like cuts are not worn out.
However another problem could be a broken motor coupler.
Thank you for contacting Fixya.com
Aug 09, 2009 | Whirlpool Washing Machines
Whirlpool topload filss, will not agitate, spin or drain.
This sounds like you need a new motor coupling and an agitator repair kit on this unit. We have parts and will be happy to assist you with your repair.
When you purchase your parts through us, we provide part removal/installation instructions.
You may contact us at:
WWW.Accurate-Appliance-Service.com
We look forward to working with you and hope this gets your washer in good working order again.
Have a great evening, Ella
Apr 16, 2009 | Whirlpool LSR5132PQ Top Load Washer
Agitator runs at a very slow pace.
it sounds like the belt may be stretched not allowing it to agitate as it should
Jan 17, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
163 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
