Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Blows warm air, unpluged it for 2 days plugged back in blew very
Blows warm air ,warmed fridge to 70 degrees, unpluged it for 2 days,plugged it back in blew cold air again 10 degrees in freezer, next day blowing warm air again
  • Frigidaire Master
  • 4,655 Answers
Either the start relay and start capacitor or the Adaptive Defrost control is burned out. If you have a voltage meter we can test a few things like the compressor and the capasitor. The part number for the Adaptive defrost is 241508001 and found inside the fresh food compartment behind the control panel. I can help you locate the problem if you like. Let me know, Thanks, Sea Breeze
Posted on Jul 18, 2009
  • 2 more comments
  • John Tripp
    John Tripp Jul 18, 2009
    Here is a link to my site and search feature. I want you to unplug and open the control panel. and have a look at the Adaptive defrost.Sea Breeze
    http://servicepartstec.blogspot.com/
    PART NUMBER AND MODEL SEARCH FEATURE
  • John Tripp
    We may want to have a look at the thermostat too. Sea Breeze
  • John Tripp
    If one of the fans is defective it will cause the same symptoms as you mentioned in your post. Sometime they will run
    for a while and suddenly stop causing the warm air again, Sea Breeze
  • andres correa Apr 30, 2013
    hello I have a friend john nevecon this card com 241508001 which you mention what happens that is not sending the cold to the other compartment and ice this out too for the drawers in the bottom of the fridge where ba I wonder if there a way to test the card or if you definitely need to change or could be. As would be the cost of the card
Refrigerator
The self defrost mechanism is not working. The evaporator is getting blocked with ice, an insulator, and that affects freezer as well as refrig temps. When you unplug unit the ice melts and it will work till the ice block returns.
Sep 07, 2016 | Refrigerators
Westinghouse fridge warm freezer -25 degrees
ok the freezer should be at 4degrees f and the fridge should be at 37 degrees f...sounds like the compressor electronics need to be replaced
Jan 10, 2014 | Refrigerators
E1 Error on air conditioner
It's time to call a professional. Call the manufacturer and ask them who they recommend in your area. Note :Some questions can be answered if you put enough information such as brand and model number.
Mar 25, 2017 | Haier HWR08XC7 Air Conditioner
My refrigerator went warm overnight, I unplugged it took the back off and seen a little black box that said electronically protected and plug's into the electrical part on the side of the compressor I...
What you describe sounds like the relay overload package that starts the compressor. Blowing on it should have no effect except if the overload overheated and was stuck in the off position. I would replace the relay package.
Feb 26, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
This frigidaire (side by side) only blows warm air on both sides
Good day,
First, I would unplug the machine, and then unplug the ice maker. Wait 20 minutes and plug in refrigerator. See if it cools without the ice maker in the equation.
Sounds more like starting components on the compressor, or a compressor starting to fail.
Post back with results.
Thank you.
Feb 12, 2010 | Frigidaire FRS3R5EMB Side by Side...
Freezer works fridg dosent stay cold
When plugging it back in, check to see if you can feel air circulation (from vents in the top-rear) on the refrigeration side.
Check again after the fridge starts to warm.
There is a fan which is supposed to distribute the cooled air from the freezer to the fridge; this may be failing after the fan has warmed from operation. The bearings in these is primitive and can get sticky impeding the fan's rotation. Replacement of that fan is not covered by the (longer) compressor warranty.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a 7 year old Amana bottom freezer fridge model ARB2259CW. The freezer seems like it's freezing just fine, but the fridge is either not blowing any air or blowing very little air. Things in the...
if you can hear a fan blowing in the freezer that is probably not the problem. If it is at all possible could you clear out the fridge overnight. If so, do so, unplug refrigerator with doors open overnight and plug it in in the morning. If it returns to cooling you probably have a defrost problem, but you at least have a couple days to fix it.
Jun 14, 2009 | Refrigerators
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
Upper Fridge Too Warm
We had a warm fridge and super cold freezer.....we unplugged for about 20 minutes and the fridge started to cool down again.... but only for a few days then back to warm.
We ended up unplugging and "defrosting" the whole unit for 24+ hours ....Now it works perfectly again.
I think it happens when one or both of the doors is not shut or sealed all the way and engine works too hard and "freezes" up the fans or some other part of the system.......I am just happy I did not have to buy a new fridge.
Mar 30, 2008 | Maytag MB2262H Stainless Steel Bottom...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
526 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
