Question about GE Profile JKP18 Electric Single Oven
GE glass top and oven are not heating?
I have a GE Glass top range. I was boiling water the other night and all was good. I was installing a GFI outlet, and when I went to turn the breaker off I hit the stove breaker as well. When I turned the breaker back on to the stove the burners no longer worker. The stove has power but only after turning on any one of the range top dials. By just turning on one dial the clock will come on the oven lights will work... everything excpet any of the heating elements? Did accidently tripping the breaker fry some fuse in the oven or is there any sort of reset button? Any advice would be great. Thanks.
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Posted on Oct 20, 2009
  • Al Robertson Feb 20, 2014
    It turned out that last week I had cleaned the warming tray, and pulled it out to vacume under the stove. Since it is a built in range, I didn't even think about the cord. Apparently it had worked its way out, while the clock and fan work on 110 you need the range to be totally plugged in. replugged it works great!!! Thanks for giving me a hint.
  • 1,543 Answers
Sounds like you are only getting 120 volts to the range. Make sure you are getting 240 volts across the two outer terminals of the range power block (where the incomming power connects to the range) and 120 from each of these to the center nuetral.
Posted on Jul 18, 2009
How can you remove burnt plastic from electric hob oven
from the ceramic or glass cook top
will be a slow process cant scratch the top
hope its not tuppa ware
it will smoke
plastic scraper or solid plastic spatula
with hob off .. boiling water little at a time
may have to low heat the hob again
Apr 16, 2017 | Ovens
Where can I get a heat resistance double sided tape to affix the external glass of the oven to the SS frame on my slide in GE stove .
Most of the time that GE attaches any type glass to hot metal these days they use silicone seal. It is uses to attach glass cooktops into the metal frame of the cooktop. Get a tube of GE clear silicone seal and glue the glass around the complete edge getting a good seal and contact at the glass edge and metal panel. Let it dry 24 hrs before reassemble. The silicone seal turns to rubber when dry and is quite heat resistant. It won't stand up to direct flame but should hold your glass well.
Apr 27, 2015 | GE Ovens
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
How do i replace oven heat element? It is a GE Profile electric glass top range, model # JBP90WV2WW serial # ZM203767G
Turn off the power to the oven. Remove the oven racks. Unscrew the element retaining screws on the rear wall. Carefully pull the terminals out of the back wall of the oven. Remove the wires. Place the wires on the new element,slide it into the opening,tighten the screws,replace the racks,turn on the power.
Nov 12, 2009 | GE Ovens
The inside of my self cleaning smooth top range
Using any kind of cleaning solution can cause the self-clean catalytic coating to be damaged. The glass itself isn't sensitive but don't apply anything like oven cleaner or other caustic cleaner to any of the other surfaces unless your owner's guide specifically permits it. On the glass, I have on occasion used a new single-edge razor blade to remove any heavy, baked on splatters and then conventonal glass cleaner to finish.
Sep 07, 2009 | Ovens
Burnt sugar caramelized on a Jenn-Aire glass cook top
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuuf really works
Mar 14, 2009 | Jenn-Air JJW8230D Electric Double Oven
Stove top burners on glass stove seem to have a governor on them
My initial attempt at solving the problem was to contact the GE customer service phone line.  When I explained the problem, the representative had no clue how to solve it, and referred me to the service organization.  The representative at the service organization was equally clueless, and suggested scheduling a service call at $100 plus parts and labor.
This is all quite disappointing; these customer and service representatives obviously have no training in solving the simplest of problems.  This is okay if GE's goal is to maximize service revenue.  But, I can tell you I would be very unhappy to have a technician visit my house, for $100, only to be told I was using a pot or a pan that was designed incorrectly for a glass cook top.
I solved the problem by going to the web site www.geappliances.com, opening the user manual, and looking under trouble shooting.  The first problem mentioned is exactly as described above.  The problem is inappropriate cooking appliances.  It is not possible to transfer heat efficiently if the pot you're using has a rim or lip on the bottom.  That is, the pot must sit flat on the glass cook-top, it cannot be raised off the cooking surface by a lip that elevated the pot from the surface.  These pots are designed to be used with gas flames, not a glass cook top.
Dec 08, 2008 | GE Profile JTP18 Electric Single Oven
Replacing glass top stove HELP!!!
You can buy replacement tops for your range. Check with your manufacturer for local parts distributors or service locations and they should be able to find you one. There is also online part stores that sell them like http://www.partadvantage.com/store anywhere from 150-400$
Feb 04, 2008 | GE Profile JTP18 Electric Single Oven
Replacing glass top on stove
I also have a ge spectra with a broken glass.
Jan 14, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile JKP18 Electric Single Oven Logo
445 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
