Question about Fisher and Paykel GWL11 Top Load Washer
Will not turn on
I went to start the machine the power turned on then nothing. i reconnected plugs tripped the breaker. nothing.
  • 4 more comments
  • overwhelmed Nov 21, 2007
    First the washer would not go through all the cycles and would signal that it had stopped somewhere before the rinse cycle and wouldn't drain all the water so clothes were still soaking when you took them out.
    Then today it will not even turn on at all. I checked all the breakers, etc. and plugged something else in the the wall outlet to be sure it was not an electrical problem.
    PLEASE help me if you can,,,,I need this fixed is holdiay weekend, plus we had a death in the famly, and my mother just had a stroke and we have to go there after the funeral, and I have 6 kids to wash and get ready to go.
  • disee Dec 03, 2007
    We've got power. The board lights up no function
  • Anonymous Apr 21, 2008
    When turning on the machine it lights up as normal, but nothing happens. I have unplugged the machine and reset the taps a few times and still no result. It has happened before and then started again, but this time it won't.
  • Kelly Wilcox Jun 05, 2008
    I have no power at all after replacing the drain pump, I tested the power plug and checked for continuity all the way to the main power plug in the control head. and I have power to the control head, but when I plug the unit in (normally all the lights flash) nothing happens, and no lights come on.
    Has anyone had this problem before?
    I think I am going to have to buy a new controller, but the darn thing came on before I switched the pumps, and I even disconnected the new pump and still nothing.
  • joker120 Jun 14, 2008
    Washer was running started spin cycle then just stopped.Breaker was not tripped plugged the dryer into washer outlet and it worked. Do you know why it doesnt come on at all?
  • Anonymous Apr 24, 2009
    My Frigidaire wash machine will not drain. Both hoses are clear and the drain pump has been replaced. It seems like the pump isnt even turning on, which is why the first one was replaced.
  • 28 Answers
If led'slight up when POWER button pushed but nothing happens when START button pushed ITis likelt to be lid reed switch open circuit or pump is open circuit .If nothing lights up when turned on at wall socket suspect controller dead or pump open circuit.Pump sounds like it has caused problem joker 120 need to check loop resistance of pump 35ohms for Aus/NZ
Posted on Jun 18, 2008
Perhaps this video walking through diagnosing and fixing the diverter valve of a Fisher & Paykel GWL11 clothes washer will be helpful.
Posted on Apr 09, 2008
  • 172 Answers
A clogged drain hose or water-pump will cause this washer not to rinse spin or drain. Can you remember at some point washing a rug with backing or pillow that came apart or any other item that could have shreaded, plugging the drain/pump?
Drain hoses and water pump can be remove and cleaned by tipping the washer forward to access these parts underneath the machine. Remove any stand water before. A handyman can do this for you.
Now as far as not turning on, I do not know about this. Did you smell an electrical burn coming from the rear top of the machine at anytime? This would be the electronics control board. A $300 item and probably not worth repairing since this GWL EcoSmart series is not a long life machine, less than 5 years.
Posted on Nov 29, 2007
  • Jrussell789 Nov 29, 2007
    The Fisher Paykel GWL series machine has three parts that can fail; water-pump. diverter valve, and electronics control board. These are all fairly easily removed to clean out drain clogs and or replace. A clogged drain hose, pump, and/or diverter valve will cause this machine to stop after washing and before drain, rinse, and spin.
    The DC Motor itself can fail, but this is rare. If your machine is more than 3 years old, I would not recommend replacing expensive parts like the motor or electronic control board.
My whirlpool washer won't turn on, spin, up, nothing model number 387298
Are you sure that the breaker did not trip?
Other than a power problem (no power to the receptacle), it would most likely be in the timer knob.
Unplug the machine and see if there is any power by plugging in a radio or a lamp....
If that doesn't work, check the breakers.
Breakers that are weak can easily trip.
Mar 06, 2017 | Whirlpool Washing Machines
My mr. coffee coffee maker does not even turn on
Have you tried another appliance using the same outlet to verify the power is on at that outlet. The breaker in the panel box nay have tripped.
Aug 26, 2014 | Mr. Coffee Coffee Makers & Espresso...
Is there a reset button
First, plug a fan or hair dryer into the plug to make sure it has power, if not, check to see if the GFI plug hasn tripped. All electrical plugs that are near water have to be on a dedicated electrical line that has a trip-breaker (GFI) built into the plug. Try unplugging the washer for several minutes to reset the electronics. Those are the only two quick fixes I can think of. If you have an electric dryer, it will have its own 220v plug and won't be affected like the washer. If the dryer is gas and is plugged into the same outlet, try unplugging the washer to reset first before you call a repairman for the washer. If you have homeowners insurance, they may cover the damage.
Jun 21, 2014 | Amana Tandem 7300 Washer and Dryer Stack...
Rancilio silvia trips circuit breaker
There is an electrical short within the machine, ...don't doubt it - the results of your experiments prove that it has an electrical fault and that your tripping circuits are doing exactly what they should to keep you and your property safe.
The machine needs servicing by a registered Rancilio electrician, don't go inside yourself, its highly likely that the part causing the tripping is dangerous and will need to be replaced.
Apr 19, 2013 | Rancilio Silvia Espresso Machine
Dryer won't turn on...
Try pushing the breaker pair off, then on and re-check the dryer. If still nothing, pull the power plug and check the two slanted slots for ~220 volts AC. If you don't have access to a voltmeter, or a friend with one, call an electrician to check. If you read the voltage stated, then the problem is within the dryer. Check the back of the machine for a reset button.
Sep 14, 2009 | Dryers
LG elec dryer will not turn on...
Check your breaker. When you swapped one of the hot legs (red and black) with the neutral (white) the breaker should have tripped as soon as you plugged it in. If the breaker isn't tripped, check the wiring diagram to see if there are any internal fuses in the control panel that might have fried.
Aug 29, 2009 | LG DLE2532W Electric Dryer
I have a ruud achiever uaka outdoor central air system, the first time i ran it this summer it tripped the breaker. It stayed on for a good hour as it cooled the house to the desired temp. then it turned...
start components are likely bad causing comp to pull high amps tripping breaker careful resetting the breaker they can explode stand off to the side
you need service all so have preventive maintenance done on the unit
Jun 19, 2009 | Ruud UAKA037 Air Conditioner
The past Few days the microwave would trip the breaker. today I went to use it and it worked for 30 seconds when I checked what I was heating and turned it bakc on and it would not work
Microwaves that are either built in, a part of the oven, or over the range are on a dedicated circuit by law. This means nothing else could have tripped that breaker but the microwave.
If it has a problem severe enough to trip a 20 amp breaker several times, it is only getting worse each time you reset the breaker and turn it on.
There is a possible chance of fire. I recommend you turn the circuit breaker off and replace the microwave. Is it a plug in, or over the range type?
May 18, 2009 | Microwave Ovens
Washer stuck
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 01, 2009 | Kenmore 42822 Front Load Washer
I went 2 turn my elect whirlpool dryer on,1st it tripped the breaker,i flipped it & it will nt start up,its getting power..though
if your getting 240v to your dryer but will not start and is tripping breakers there are a few things this could be I would start by making sure your cord is in good condition and the terminal block where the power cord is connected to does not look burned or at your wall plug.
Feb 23, 2009 | Whirlpool LER4634J Electric Dryer
Fisher and Paykel GWL11 Top Load Washer Logo
558 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
