Question about Hitachi 43UWX10B 43" Rear Projection Television
No sound I have a picture but no sound. I have checked all menu items and the setup.
    President:
  • 4,402 Answers
Powers supply or mute is on
Posted on Jan 07, 2008
Remote RMT 10 - How do I get a picture while I have sound.
It's probably your TV and not your control. If you can turn the TV on and off with the remote, turn on the TV and press the setup or menu button on the remote. If your TV is capable of displaying a picture, you should be able to see the menu items. If no menu items are visible, it is highly likely that the TV is toast. If you can see the menu, then there is a setting on the menu that is disabling your video. It may be that you have selected an alternate input, or possibly dimmed the brightness to the point that the screen is black. Work with the settings - you have nothing to loose, it isn't working anyway. If you can find a master reset, select it and it will reset all settings to the factory configuration.
Jan 19, 2015 | Westinghouse Televison & Video
Picture is going out and colors all running togeather
That sounds like a convergence issue I would check the setup menu and see if the auto convergence option is stll listed under the setup menu options or hasit disappeared? Let me know and i will assist you with the issue
Feb 03, 2013 | RCA HD52W56 52" Rear Projection HDTV
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
One cannel has picture but no sound
This could be a synch problem. Try resetting your TV to the default settings, then exit the menu (to save) and then rescanning for channels. Usually the menu item for this is Setup or Tools.
I hope this helps.
(I had this happen on a different TV and the reset worked. In my case, a digital station had one subchannel with no video and sound and the other subchannel had video but no sound.)
Jun 27, 2010 | Toshiba 19HLV87 19 in. LCD HDTV
Connection Problem with HDTV, Receiver, DVR, and DVD
check the setup menu to direct your inputs from the hdmis. its all in the setup menu. good luck
Feb 10, 2010 | Yamaha RX-V463 Receiver
My Sharp TV will only hear sound. No picture or images even from the tv menu setup option. Model# LC-19SB25U. About 1.5 yrs old. Converter box ok.
In most cases, you can reset the TV by leaving it unplugged for 30mins.
If this doesn't work, I believe the circuit board that supplies power to the screen maybe bad. They call this board a backlight inverter board. It would most likely cost more to repair than replace the TV .
May 27, 2009 | iLO 3200 32 in. LCD Television
No sound or picture but menu comes up
Check video source like DVD Player has power, check connecting cords, cable connections etc.
when TV gives menu on screen that means TV is fine and problem could be hooked video signal items.
Apr 15, 2009 | Hitachi 51F59 51" HDTV Projection...
No Sound, perfect picture but no sound
go to the audio menu setup then find the sub menu speaker after that you will see some command indicates if you want to on or off the speaker, choose the on command to be able to hear the sound in your television from your dvd player.
Aug 25, 2007 | Sanyo DS24205 24" TV
Hitachi 43UWX10B 43" Rear Projection Television Logo
24 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
