Question about Epson Stylus 880 InkJet Color Printer
Printer is plugged in but is not turning on - Epson Stylus 880 InkJet Color Printer
  • Mark Woelfel May 11, 2010
    It's probably a bad power supply, but can you plug something else into the outlet to make sure it's not a fuse?
    Sergeant:
    Champion:
  • 249 Answers
Replace cables.
Check the power button.
Try another power socket.
Posted on Jul 18, 2009
When I plug it into the usb port nothing happens, it won't turn on, is there some kind of switch I need to turn it on?
iNSTALL PRINTER DRIVER.
PLUG IN THE PRINTER VIA USB
TURN "ON" PRINTER
IF NOT RECOGNISING THEN PROBLEM WITH USB CABLE OR USB PORT OR PRINTER PORT.
Jan 13, 2011 | Office Equipment & Supplies
Cannot turn on the printer even if connections are ok ?
The only thing that could stop you from turning the printer on other than a broke printer is the power/power cord is not connected. The printer should turn on without a USB or parallel printer cable attached.
If no lights are showing when you try to power the printer, check the power connection in the back of the printer to ensure it is plugged in, check the plug into the adapter is connected and that the power cord's plug is connected to the wall outlet - if you have a power strip make sure it is turned on and the circuit breaker is not popped. Make sure that there is power to the outlet by plugging in something else to show it has power. If all of those check out ok and you have a meter, check for voltage at the power connector at the printer (pull the plug out of the printer and check voltage from inside the plug to outside the plug. It should be 18 vac.
If all of this is ok, there is something wrong inside the printer. Probably time for a new one as cost to repair is probably too high.
Oct 11, 2010 | HP DeskJet 810c InkJet Printer
X4530 InkJet Printer: printer won't turn on. Don't have ink cartridges i...
The printer should turn on even without the cartridges yet. Try this. Make sure the power cord is plugged in straight to the wall. Bypass any surge device or power strips. Unplug the power supply from the printer. It's the black box behind the printer where the power cord is plugged in. With the power cord still plugged in to the power supply, the LED around the contacts should lit solid green. If not, make sure the power cord is properly secured. If this does not help, you may have a defective power supply. If it does, insert it back in the printer in the correct position. Plug it hard just to make sure. If it does not power on automatically, press the power button. If this does not help either, I strongly suggest you contact Lexmark Technical Support for further assistance. Thanks.
May 18, 2010 | Lexmark X4530 InkJet Printer
My Lexmark x9350 only turns on and off if I plug and unplug...
This, probably, is a power issue on the printer. Unplug the printer from the computer. Unplug the power supply from the printer (it's the black box behind the printer where the power cord is attached). Try not to use any power strips or extensions for the power cord. If possible, plug the power cord straight to the wall outlet. With the power cord plugged in straight to the power outlet, plug the power supply back in the printer. That should refresh the printer. When everything's powered on, plug printer to computer. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 13, 2010 | Lexmark X9350 All-In-One InkJet Printer
Cannot turn on printer
Is the printer plugged into a power strip? Please make sure the power strip is turned on.
Also, please change the power cable for the printer as this can sometimes be faulty.
Have you tried to plug the printer into a different location, I mean into a different wall outlet.
Mar 24, 2010 | Canon PIXMA iP4000R InkJet Printer
Was printing fine. I turned the printer off and it won't go back on. Everything is plugged in correctly.
Possible hardware failure, unfortunately.
Turn it off. Then unplug it from your computer and unplug it from the wall too.
Plug it directly into a working power source. Then turn it on.
May 03, 2009 | Epson Stylus Photo R800 InkJet Printer
I can't get window (vista, business addition) to see my lexmark X4550 printer whe I plug it into the USB port. I have the lexmark disc that came with the printer but it won't let me continue the...
unloug the printer and turn it off.
install the lexmark printer software first. plug in the printer and turn it on.
Vista should see the printer and continue to install the driver.
Oct 28, 2008 | Office Equipment & Supplies
Printer won't turn on.
Try to unplug the power cable for about 2 minutes then plug it back in. Check if you can turn it on now. Double check the power plugs. Try to plug on a different power outlet.
Oct 13, 2008 | Dell 922 All-In-One InkJet Printer
Printer does not turn on - checked plugs etc - all OK It could be a problem caused by new cartridge being installed.
This just worked for me. Printer would not turn on, no lights, nothing.
Took cartridge's out, unplugged from computer and wall outlet. Waited 5 min. Plugged into wall plug first, printer turned on, plugged into computer and reinstalled the ink cartridge's and pc found new hardware ( printer ) and all was working after that.
Unplugging from wall socket and pc, was what I needed to reset it.
Jul 18, 2008 | HP Computers & Internet
Printer wont work
Check the plug and make sure that plug is in. Also make sure the outlet has juice. If possible, try another plug.
Jun 19, 2008 | HP Officejet 7210 All-In-One InkJet...
Epson Stylus 880 InkJet Color Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
