Question about iLO IWT3206 TV
How do you get a playstation 3 too work on my ilo tv
    Sniper:
  • 51 Answers
Depending where you hook it up... in front or in the back...use your remote and click on the input select button. That will turn it to video 1, video 2, ect... I believe the front connections are video 2 and the back is video 1.
Posted on Aug 28, 2009
I have an Ilo 26"
try adding another source to rule out tv issues then after that try looking up how to reset the xbox's video output i know my playstation can do it so xbox must have a defaulting setting obviosly whoever fixed your xbox left it in 1080p and your tv is 1080i minor problem just mildly frustrating ok hope this helps
Nov 17, 2010 | iLO 3200 32 in. LCD Television
ILO TV REMOTE CONTROL MISSING
Go to this webpage.
Here you can buy the original remote contol for your TV
http://www.remotes-express.com/Ilo/ILO2600.html
Jan 12, 2008 | iLO 2600 Television
My ilo tv will not change from channel 3. The
You may have accidentally pressed 'Favorite' on the remote which will lock the controls. Try pressing 'Favorite' to unlock the controls.
Jul 10, 2010 | iLO 2600 Television
ILO 26HD TV: After playing Playstation, the TV
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Feb 22, 2009 | iLO 2600 Television
The tv do not work
poer supl. do no work: solusion 3 capacitors 16volts 1000uf . now is workink ok.
Dec 19, 2008 | iLO 3200 32 in. LCD Television
My ilo tv wont hook up to my playstation on any channels.
Try plugging into the Component Two jacks (down along the left side). I couldn't figure out mine either, so was resorting to unplugging and plugging in the game when I wanted to play. I had the DVD in those jacks originally. Now the TV is stuck, not responding to either the remote or it's own buttons (except off and on), so we are switching 3 different types of entertainment in the same jacks. It'll work for the time being.
Dec 02, 2008 | iLO 2600 Television
Ilo TV codes
Here are two more codes you can try they worked on my RCA 600M Universal Remote:
191 or 208
they both worked for the volume and channel up and down, I am still looking for a code that will get me to the menu, on screen info and allow me to change from TV to ANT1 ANT2 and Composite.
May 23, 2008 | iLO V27DMBX Television
Ilo tv
i dont think that the ilo has a sound output port:(
Oct 17, 2007 | iLO V27DMBX Television
Remote problem
I understand Ilo's are made by Tatung. You may try 0055 or 0003. I haven't confirmed this, but it's worth a try. http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
Aug 24, 2007 | iLO 2600 Television
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
iLO IWT3206 TV Logo
123 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
