Question about GE Profile PSI23NCR Side by Side Refrigerator
HAVE REPLACE THE FILTER, NO WATER OR ICE WHEN FILTER WAS OUT MADE ONE BATCH OF ICE THEN STOPPED NO NOTHING WATER IS ON NO KINKS IN HOSE WHAT IS WRONG THANKS ROSE
  • GE Master
  • 1,606 Answers
Try putting the old filter back in . Just because the " change filter " light comes on , does not mean to actually change the filter if your water dispensor is not just trickling out . If water was coming out fine before replacing filter , no need to replace it just because ot the indicator . I have found new filters which worked worse than the old filter . Just put the old filter back in and problem solved .
Posted on Jul 18, 2009
Will changing water filter fix my lack of water from water dispenser
Hi, How old is the filter? has it always been like that? Could be the filter but I believe that if you changed the filter before then youneed to look at the water supply. Should be a valve with a bar or wing looking extension, turn the valve counter clock wise untill it stops, don't force it when it stops turning, thats all it will turn.. Check if that made any change, if not look inside the refridgerator compartment in the back behind the bins. you will see a coil of plastic hose, make sure that it is not kinked or bent sharply, the hose has a tendency to pinch off the flow if it is kinked. good luck
Sep 30, 2014 | Samsung RFG298HDBP French Door...
I replaced my water filter. Now I have now water dispensing and no ice being produced
Did you turn the tap back on? Has the hose kinked in the back of the fridge where the filter is? Is the filter back in its place properly (If mounted inside the fridge)
Sep 18, 2014 | Samsung Refrigerators
What to do after new water filter installed ice stopped being made?
Need to change water head (the part that the filter fits in).
Aug 29, 2014 | Sub-Zero 650 / O Bottom Freezer...
Low water pressure to ice maker and water dispenser
sounds like bad water valve not opening all the way
Nov 30, 2013 | Refrigerators
Hi I have a GE Fridg. #GFSL6KEXALS Just has ice in bottom freezer, no water. Ice maker quit working, Does not seem to be filling with water.
Check the water line that goes from the house plumbing all the way to the inlet on the 'fridge. Are there any kinks? Dirt obstructing the line? You MUST BE VERY CAREFUL when pulling the 'fridge out to check. If you have a copper line, it takes NOTHING for one to kink. And as soon as it kinks...it's done.
Feb 23, 2010 | Refrigerators
Whirlpool gold moder GC5SHEXN503 side by side-ice maker not producing ice anymore--water dispenser works fine--laser lites seem ok---no ice jam--no water filling ice molds
Put some water in the ice maker and see if it will kick a batch out. If it does make a batch but does not make any more then replace the water valve. NOTE: the water valve is a dual purpose valve that supplys water in the door and supplys the ice maker. If the ice maker does not kick out a batch then something is wrong with the ice maker.One easy component to replace is the ice mold thermostat.
Feb 20, 2009 | Whirlpool GD5SHAX Side by Side...
Icemaker stopped making ice. Replaced icemaker. Still no ice
Pour some water into the IM. If it kicks out a batch then replace the water valve. If it don't then get a refund. The IM is it's own master. It has a thermostat to determine when to initiate harvest and it is the one that calls for water. If your freezer maintains 28 degrees F and the water valve, water filter (if applicable) and ice maker are all ok then you should have ice.
Jan 17, 2009 | Refrigerators
Frigidaire Gallery Series M# GLHS36EESB5 S#LA53808237 The indoor water dispenser stopped. I replaced the filter but nothing changed. The fridge is 18 months old.
check to make sure there is nothing blocking the water lines and no kinks in the water lines, you did not say if it had an ice maker, and if it is affected.
The frigidaires also has a plastic tube coiled under the back to dispense cold water make sure this tube is not kinked.
Hope this helps
Jul 02, 2008 | Frigidaire Refrigerators
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
GE Profile PSI23NCR Side by Side Refrigerator Logo
188 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
