Question about Maytag Neptune MDE5500AY Electric Dryer
How do i take the drum out of my maytag neptune dryer
  • 234 Answers
You need to first remove the door (4 screws on the left side and 4 on the right where the door is located (should be philips). Then you need to remove that front frame by removing a bunch of 5/16 screws with a nut-driver. Then the top cover comes right off and then you can remove the belt from the pully and remove the drum. It's kind of complicated but if you do it once or twice, it gets simple. Good luck :)
Posted on Jul 18, 2009
  • 146 Answers
SOURCE: change rollers on a Maytag Neptune Dryer
You have to work from the front. Pull the top then the front then you will be able to see everything. Pretty self explanatory.
Posted on Dec 22, 2007
CMV9
  • 594 Answers
SOURCE: We have a maytag neptune
i would replace the belt usually over time the belt streaches due to the weight of the clothes. the screaching ou are hearing is probably the belt going aound the drum instead of turning the drum.
Posted on Aug 16, 2008
SOURCE: How to remove a back panel of maytag neptune dryer?
Catriver was right on the mark. Took a little bit of doing but I was able to fix the problem myself within 30 mins, and saved some money. Many thanks. I'd like to expand Catriver's solution a bit.
I found a layer of lint on the inside bottom of my dryer. With the face off of the dryer, it proved to be a good time to vacuum the lint out and reduce the potential of fire.
Posted on Sep 07, 2008
SOURCE: Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Posted on Nov 21, 2008
bomark2002
  • 160 Answers
SOURCE: MayTag Neptune MDE6800AYW dryer drum making
Have someone change the bearing, it sounds like it has busted on ya. The rumbling sounds like the ball bearings in the bearing have failed.
Posted on Jul 09, 2009
How do I change the drum belt on maytag Neptune dryer
have to remove the whole front section including door the top will flip up after u remove front and screws which were hidden until u removed the front section
Oct 12, 2014 | Maytag Neptune MDE4000 Electric Dryer
The beater bar in my Neptune dryer modeL # MED5500AYW has come off and needs to be replaced.
It sounds like you are referring to the drum baffles when you say "beater bar". If that is so, you need to remove the front panel then raise the top cover to access the baffles mounting screws outside the drum. Below is the link to the procedure I posted previously.
Maytag Neptune Dryer Front Panel and Top Cover Removal
Sep 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes squicky noise while drying
its the drum glides/slides that support the front part of the drum open the door and push on the door switch and start the dryer and you will be able to locate the noise source easily
Apr 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Electric Dryer Broken Drum
look in your owners manuel and see if the drum is covered.
Jun 23, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
What is the drum capacity size on the orig maytag neptune washer?
Drum size or capacity for the Neptune Model Number MAH4000AWW is 3.4
Jan 03, 2009 | Maytag Neptune Washer
Dryer Drum Wont Rotate
did you check to see if the belt was not broke? if not possibly the motor went out.hope this helps
Dec 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Change rollers on a Maytag Neptune Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
184 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
