Question about Mitsubishi WD62628 62" Projection HDTV
My 73' rear projection Mitsubishi turns on, an in
My 73' rear projection Mitsubishi turns ON, and in 30 sec screen blackens from the bottom up, leaving only about 5 inches on the top. Then, in another 30 seconds, turns completely OFF. Immediate attempt to turn it ON results into the immediate OFF. Unplugging from the power outlet for about a 1 minute just resets the above described cycle.
  • 668 Answers
It Sounds like to me that there is something with in the Optical block causing the problem.
I would recommend a professional to look at it and confirm this.
Hope this helps,
Skyassoc
Posted on Jul 18, 2009
I have picture but no sound on my mitsubishi 73 inch DLP tv how do i fix
check to see if with a rear audio/video input you have sound (DVD etc)
look in menu speakers are not set to off or external
try the reset: Menu 1,2,3, enter.
Dec 22, 2012 | Mitsubishi WD-73827 73" HDTV DLP TV
73' dlp white lines lots of them
The problem is in the flyback transformer, or there is a open resistor in the video output, one possible solution is adjust the screen control on the flyback transformer a very slight tweak anti-clockwise, this in a lot of cases will fix the problem, but you must use extreme care, "high voltage danger"
Apr 14, 2012 | Mitsubishi WD-65000 65" Rear Projection...
I nannot turn off cations on 73 inch tv
look for a button on the remote most probably labeled " CC " or go into the menu in the audio or setup section and you should find the closed caption settings.
Jul 31, 2010 | Mitsubishi WS-73713 73" Rear Projection...
Older rear projection 63 inch Mitsub. A brown block
Ur convergence is dead.Must replaced 2 Convergencce ICS,and some or all it resistors.Can u solders?Buy a convergence kit at Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi screen replacing
You must remove the front bezel and frame holder to replace the screen. You will usually see the screws holding the from from the rear of the unit. Once you get the frame off, take note of the way the old screen is installed. There is usually a label on one side near the bottom; the new screens must be installed with the label in the same location. The lenticular goes on the outside (facing the viewer) and the fresnel goes on the inside facing the mirror. You will be able to recognize the fresnel, it has a series of concentric circles that are raised on the sirface of the plastic Be sure to rate this solution.Thanks!
Nov 08, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Oval shaped picture problem with Mitsubishi WS55807
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is
Nov 21, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WD62628 62" Projection HDTV Logo
127 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
