Gums and pain,moving to the ear.
The chioce can be made between an orthodontist or an general practitioner not in first place your dentist who do not usually give their own fault as another orthodontist discovered him maybe you can have a sinusitis maxillaris because of the inflammation of the tooth root tips and that could be a problem of or you have a dentist with bad old x-ray equipent where it will hard to see if there are leaking fillings much better to see with Doerr X-ray equipment Orthodontist have this kind of tools for a good research or it can be caused by wrong dental hygiene or an accident with breakage by heat or unexpected on a hard object bitten. its better to stop smoke in this case if you may be smoke.
when a plane
ascends and descends, it affects the pressure in your ears and this can make
them feel blocked and sometimes very painful. You should try yawning and
swallowing. Some people find that chewing gum is really helpful to use when the
plane is taking off or landing.
If you have a cold or cough, you should take a decongestant before you fly to try and minimize the discomfort.
