Trying to install antec 350w power source to gateway (2001) computer. Cannot figure out where p5 connector attatches.
  • 672 Answers
Just make sure all of your hardware is connected. Not all the power connecters need to be connected to a device. Some may be left disconnected with no problems.
Posted on Jul 18, 2009
  • 64 Answers
I would guess that it's hanging out around the processor area. It looks almost identical to what the PS side does. It would just be the female end.
Good day: Im having some issues with my washing machine some times when I start my machine appers the error F51, the model number is 11027082604 type 580.
The F51 error code refers to a failure on the rotor position sensor,the test procedure for testing the RPS can be quite involved. Here is the test procedure
;TEST #3 Motor Circuit
This test checks the wiring to the motor and rotor position sensor; and the motor and rotor position sensor themselves. NOTE: Drain water from tub.
1. See Activation of Manual Diagnostic Test Mode, and check the motor and electrical connections by performing the Agitate and Spin tests under Manual: Motor. The following steps assumes that this stepfailed.
2. Unplug washer or disconnect power.
3. Check to see if basket will turn freely. If basket turns freely, go to step 4. If basket does not turn freely, determine what is causing the mechanical
friction or lock up.
4. Remove the console to access the machine/ motor control assembly. See Accessing& Removing the Electronic Assemblies.
5. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 6.
If visual checks fail, reconnect P5 and P10 and repeat step 1.
6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7 and verify that the resistance is within the range shown in the wiring diagram on page 7-1.
If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to
step 7.
7. Tilt machine forward to access the bottom of the machine and the drive motor area. See Figure 1 on page 6-13. Remove the motor bolt, then the motor cover to access the motor connections. See Figure 2 on page 6-13.
8. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check passes, go to step 9.
If visual check fails, reconnect the electrical connections, reassemble stator and motor cover and repeat step 1.
9. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector. See Figures 2 and 4, pages 6-13 and 6-16. If there is continuity, go to step 11. If there is no continuity, replace the lower machine harness.
10. With an ohmmeter, check for continuity between all pins on the P5 machine/motor control connector and the drive motor connector. If there is continuity, replace the drive motor. If there is no continuity, replace the lower machine harness.
11. The drive motor and lower harness are good. Replace the motor RPS board and perform the Diagnostics test in step 1 to verify repair.
12. If the Diagnostics motor test in step 1 failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Motor Diagnostics in step 1 to verify repair
IF THIS SEEMS GOBBELDY GOOK TO YOU CALL FOR SERVICE
Jul 30, 2011 | Washing Machines
We are getting a F51 code on our washer. What does that mean?
Hi
F51 error is a rotor position sensor error. This error appears when rotor position sensor is faulty or due to a faulty control board. Look underneath the tub and check the motor, check for RPS on the right side (follow the brown wires) and under the motors rotor disk. Use allen wrench to remove the rotor and then the four bolts holding the motor stator to the tub can be removed. You would need to check the motor by running Motor test. Please follow the steps ---
1. Unplug washer or disconnect power.
2. Check to see if basket will turn freely.
3. If basket turns freely, go to step 4. If basket does not turn freely, determine what is causing the mechanical
6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7 and verify that the resistance is within the range.
If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to next step.
12. If the Diagnostics motor test in step 1 failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Motor Diagnostics in step 1 to verify repair.
Nov 16, 2010 | Maytag Bravos MTW6600T Top Load Washer
I have an Antec full tower with a 350W power supply it seems somewhat old...i hooked everything up inside and tried to turn it on but it would not turn on any suggestions?
First, is there power from the power supply? Is the power supply turned on in the back? If there is powere to the Mobo, then the mobo is likely the problem. The cpu fan fan should spin if there is ower to the board.
Apr 20, 2010 | Computers & Internet
Gateway PC into Antec enclosure?
Hi:
You should be able to transfer your motherboard to the new case, but some things to check before you do:
How do the power switches and front audio/USB connections work for the old gateway? Are they standard or vendor specific? Are the optical drives in the gateway standard, or do they have special fronts on them? I have done what you are wanting to do several times, and often you need to replace OEM optical drives, and sometimes the motherboard headers don't match up with a builder case, so you do the best you can.
Dec 11, 2009 | Antec Aria - MicroATX Cube Case W/Power...
I need help installing a cd drive in an Antec Sonata III 500 computer case. How do I do it?
Unplug the power from the computer. Open the case cover. Carefully remove the placeholder on the front of the case where you wish to install the CD drive. Make sure you have the proper ribbon cable for the type of drive you are installing and that you know where to plug it into the motherboard (consult your motherboard manual).
Use the screws provided to secure the drive to the chassis rails (make face of drive flush with front of case). Attach an available power supply connector to the new CD drive. Close the cover.
Dec 04, 2009 | Antec Sonata III 500 - mini tower - ATX ...
What power supply is in the et1161-07? I am looking to upgrade the graphics card to a nvidia 9500, 9600, or 9800. They all require different wattages.
The power unit in question is a 250W supply unit. Nvidia series 9800 cards require 580W, the 9600 series require 300 - 400W, and 9500 series require 350W. All of these will require a new power unit. Antec is a more than adequate. Any computer shop should have a 600W unit for $100.00.
Jul 13, 2009 | eMachines Computers & Internet
How do you fix code f 51 on the top loader cabrio washing machine
F then 51 flashes when there is a motor rotor position sensor (RPS) failure. See TEST #3
Motor RPS Failure
here is what test 3 is... good luck...
step 7.
Apr 28, 2009 | Whirlpool WTW6400SW Cabrio Washer
P/S replacement in Gateway 2000 model year Tower
Gateway may have a unique non standard pinout for its P/S. I would match up the colors in sequence on the new PS and see if the old harness had the 6 pin connector and graft them into the new harness. The colors are standard for voltage.
Feb 11, 2008 | Antec TruePower Trio 550 (TP3550) 550-Watt...
Red Light on Board
it is better to use the old power supply because it is compatible to your mother board
Feb 11, 2007 | Soltek SL-K8AN2E (SL-K8AN2E-GR)...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
