Question about Canon Office Equipment & Supplies
I need access to the user manual for the canon faxphone b-740
The fax machine rings but doesn't receive the fax. gives a message ''no answer''.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 217 Answers
Probebly the machine is set on "manual receiving" in stead of "automatic receiving".
Change the settings and try again.
Good luck, Gerrit Jan
Posted on Jul 23, 2009
My canon faxphone L80 keeps saying check cover. I opened and closed the cover. I removed the ink cartridge and don't see any paper jammed. If I unplug and replug the machine the message temporarily goes...
hi, i think that somone was oppened the cover by force, that can damadge the cover switch. open the front cover, look inside is there any foreign body, is the cover switch looks fine, look at this picture from the user guide page 152: mabroukmedal_6.jpg
Nov 03, 2010 | Canon FAXPHONE L80 Laser
WANT TO ATTACH A MESSAGE MACHINE
The message machine needs to be set to answer 1 ring before the fax is set to answer. When the phone rings the fax starts listening even when the answer machine picks up. If the fax hears fax tones it will receive the fax and if no tones the answer machine will take a message.
Jan 22, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Not able to receive Faxes from a Canon Faxphone L80
Describe 'Lots of noise'.....was it static? Or high pitched varying tones (also known as handshake) Normally the two beeps are after the 'handshake tones' which means that the fax is awaiting an answer from sending machine. If you don't mind, email me your fax number so that I can hear exactly what you are hearing. tswiercinsky@yahoo.com
Nov 18, 2009 | Canon FAXPHONE L80 Laser
Faxphone keeps ringing but no fax emerges.
1)firstly u hav to press [data registration ]>#,it show [SSSW]>shift arrow right until u can see [type]put it to uk region then press ok.reboot the machine .Proceed with transmission and receiving fax.Good luck ,pls feedback to me if u have any query.
Jun 30, 2009 | Canon FaxPhone L75 Plain Paper Laser
My Canon Faxphone L80 will receive but will not send.
Call the fax number from a regular phone to hear what's going on
Mar 02, 2009 | Canon FAXPHONE L80 Laser
Canon faxphone will not recieve fax
Most of my fax mahines I setup,I setup with the fax only mode,and then I change my incomming ring to 7.This give you enough time to answer the phone and minnimize the risk of losing faxes.If a external phone is connected to the phone and you receive a fax call,you press 25 on the external phone and the fax switch to rceive.
Feb 27, 2009 | Canon FAXPHONE L80 Laser
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
Receiving a fax
Press recieve mode repeatedly until manual mode is displayed.
after a few seconds the display will change to the month/day manual.
when the telephone rings and you answer it if you hear the beeps etc press start/copy and hang up handset to print doc.
Jan 29, 2008 | Canon FaxPhone L75 Plain Paper Laser
Hooking up a fax machine on home telephone line
Well... the problem is that you are running two machines on one line. ONE of them has to take predominance. Both machines should have settings for "number of rings to answer at". It sounds like you currently have the fax set to less than the answering machine, so the fax picks up after two rings, while your answering machine might be set to more, which it never gets to, because the fax answered the call already(It doesn't matter if you answer the phone, or the fax picks up, once the line is open, the answering machine is taken out of the equation). Even if you set the answering machine to answer first, you're then taking the fax service out of the loop. I'm not sure how you're going to juggle that, since both types of machines each need control over the line to work properly. That's why we (business machine folk) always recommend a dedicated line for fax service.
Jan 23, 2007 | Canon FAXPHONE L170 Plain Paper Laser
50 people viewed this question
old marine
old marine
