Question about Sylvania L181 18.1" Flat Panel LCD Monitor
Sylvania L181 18.1, Black screen
Screen goes black when room temperature is cool, if room is warm, no problem. What could be the problem?
0 characters
1 Points
After some time LCD going to black screen till again power on
Do you have a Video Picture for a short time and soon after the picture drops out and the screen goes black?
If so, when the LCD gets warm/hot a Diode shorts out and the screen can shut down. If that is the case, you may need to replace the screen. A technician needs to test the circuit board to see if a short is occurring in that hardware as this could be another fault.
Dec 25, 2013 | HP W1907 19-inch Widescreen Flat Panel LCD...
Haft of the screen is black.
Most likely, it is some capacitors in the inverter or power circuit that is dying. Check out
Dec 16, 2012 | Sceptre 46" 1080p Lcd Hdtv X460bv-fhd
My screen goes black after a few seconds
Sounds like a bad solder joint on the printed circuit board. Once it heats up then it no longer makes good contact and the monitor goes black until it cools down and makes contact again. You could resolder it if you knew where it was but monitors are dangerous to go playing around with as they can hold very high charges of electricity in their capacitors that are very dangerous. It's a throw away world. Go buy a new one.
Jun 02, 2009 | Gateway FPD 1750 17" Flat Panel LCD...
Black screen at start up?
IT SOUNDS THAT YOU HAVE A COLD SOLDER !! open the unit and check out the printed board and look around the transformer for a burnt or cold solder , re solder it and youre good to go , let me know , AJ
May 05, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Brightness is off - screen is black - I can force it to work by toggling the stand-by button on my Acer Aspire 5100 - is it the driver or will I need to get an inverter? Screen went black but the computer...
i cant sugest anything but what i can say is that i think you will have to get a new screen that is my oppinion.
sorry for the inconveience.
please rate for my help to you.
thank you.
Apr 22, 2009 | Acer AL1917W LCD Monitor
Monitor goes black
dry soldring problem in your monitor
Mar 31, 2009 | Acer AL1751WM (Silver) 17" LCD Monitor
Samsung monitor troubleshooting
my computer power is on and my computer also start quick but the screen of the this moniter start after 15min to 30mins this problem how to solve.
Aug 23, 2008 | Samsung SyncMaster 540N 15" LCD Monitor
Acer AL1716 monitor flickers
i Have the same problem, this screen is used on the spare computer we have in a loft conversion and the room does get rather cold, Warming the screen up with a fan heater for a couple of minutes gets rid of the problem. When the fault occurs the buttons on the front to adjust the picture quality don't work they just turn off the monitor.
Dec 08, 2007 | Acer AL1716 17" LCD Monitor
Screen goes black after a few minutes, switching off and on and picture returns then goes black again
I have problem with my monitor, it is automatically switching off and switching on for 2 to 3 minutes for every 15 minutes why ?
Please mail me the solution to
Oct 21, 2007 | Relisys RLT1720 17" LCD Monitor
Faulty monitor
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
May 11, 2007 | Proview XL370B (Black) 17 in. Flat Panel...
Sylvania L181 18.1" Flat Panel LCD Monitor Logo
Top Sylvania Computer Monitors Experts
micky dee
Are you a Sylvania Computer Monitor Expert? Answer questions, earn points and help others
