Question about Toshiba Satellite (K000004080) Motherboard
Toshiba Satellite temperature related freeze
From a cool state, the computer will boot as usual and work perfectly for a max of about 5 min, and freeze. trying to turn back on will freeze right at the toshiba screen, and sometimes constant internal beep. if let cool, however, the first time will run all the way just fine again.
from a service center recommended by the toshiba support line, a new fan was installed, but didnt fix the problem, so they said new motherboard.
agree, disagree?
whole new thing?
maybe just a bad solder, fixable?
thank you gurus
  • 81 Answers
Hum that could be right to avoid wasting money, please get a new board, but if u can get a processor and ram to test with, u might be lucky, right
Posted on Jul 18, 2009
Toshiba M115-S3144 that freezes after starting
make sure your ram is upgraded to max capacity
see
http://www.crucial.com/systemscanner/
DDR2 PC2-5300 2x2gb chips
update windows including ALL optional updates
Jan 10, 2013 | Toshiba Satellite M105-S1021 Notebook
Toshiba M55-S139 Laptop randomly freezes without warning.
you have a diry fan try cleaning the fan motor and spray a slight amount of wd 40 on the cooling fan and it should take care of your problem, if not go buy a usb driven laptop fan and try that, it is heating up and is the fan for the cpu or the memory stick getting hot. the fan costs 15 dollars so it's worth it to make the computer work and it will keep it cooler anyway.
Jun 20, 2009 | Toshiba Satellite M55-S141 Notebook
Problems with my Toshiba Satellite L675D freezing up
start the PC in safe mode (f8 on boot) and see if it still freezes. If not do the system scan from within safe mode
Sep 27, 2017 | Toshiba Satellite L675DS7040 AMD Athlon II...
Hi, I have a new Toshiba Satelite L500 laptop. From the moment I started to work with it, following message began to appear: Warning: A problem with the cooling system has been detected. Please turn off...
first you should install an independent system temperature monitor like speed fan and check if your computer temperature is ok .If the temp is ok then it is not as much of a worry but more of an annoyance if it shows the computer is hot take it back to service immediately either way they should fix the problem under warranty.
I hope this helps Andrew A
Apr 01, 2011 | Toshiba Satellite Laptop Cooler
Someone have put a password on my hdd,so I can't boot into windows.can anyone help me
you did not stated where, is this on your computer? on the darddrive? on the operating system?
removing password from computer or harddrive is beyond scope of this forum. if password is on windows xp matter is relatively simple.
1. boot computer in safe mode (pressing f8 key during startup will give you choice)
2. log in as administrator
3. press "start"
4. select "control panel"
5. select "users"
6 . remove password
7. restart computer and use normally
if this do not work, find on the net any of free available password removal programs, create self-boot floppy or cd with program, follow instructions.
Jul 29, 2010 | Toshiba Satellite Pro L300 Notebook
Boots up windows runs for 5 mins then system shuts
You may have a cooling problem (with older computers), if you hear your fan running excessively and then it shuts down on you. Otherwise it is more likely a hard drive issue.
Jan 25, 2010 | Toshiba Satellite P25-S5263 Notebook
Memory Upgrade problem
You have the correct memory, however, did you replace memory in both available slots with same capacity/clockspeed sticks? The below is from the Spec sheet for your computer.
512MB(min)/2048MB (max), 2 memory slots using 256MB, 512MB, 1024MB or 2048MB PC4200 DDR2 533MHz SDRAM,
dualchannel support requires two memory modules of same capacity and clockspeed
Mar 22, 2009 | Toshiba Satellite P105-S6227 Notebook
My toshiba Satellite A135-S2276 boots up normally and then before it freezes I hear a static sound coming from the speakers and then computer does nothing at all
the problem seems to be related to static shock affecting toshiba mousepads, speaker grills, and USB ports. It's a common problem, and it is affecting my Toshiba laptop too. Here's an article I came across trying to diagnose the frequent freeze-ups:
http://forums.cnet.com/5208-7587_102-0.html?forumID=69&threadID=52744&messageID=687077
Jul 29, 2008 | Toshiba Computers & Internet
My Toshiba Satellite M45-169 keeps freezing
1. The battery on the motherboard has died. Replace battery.
2. The BIOS is corrupt, reflash BIOS.
Most likely #1, very rarely #2. Pop out the battery on the motherboard and replace it, after the first time you boot up your computer, go into BIOS and set everything the way it should be for your computer (usually just time and date) and then after each sequential time you reboot, that should take care of your problem.
Jun 24, 2008 | Toshiba Satellite M45-S169 Notebook
Toshiba Satellite (K000004080) Motherboard Logo
167 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
