Question about GE Spacemaker JVM1640SJ Microwave Oven
Turntable not rotating
Turntable makes noise while barely rotating
  • 6,784 Answers
HI, the turntable motor is weak and failing at this point, simply replace this damaged motor. this will eliminate this distraction.
Posted on Jul 17, 2009
  • 3,230 Answers
Well it seems that there is some fault in the turnable motor, turntable system consists of the motor and coupler, turntable support with rollers and the tray.
I have a video link to help you more on this -- how a turntable motor should sound when you rotate it by hand... please follow the below link -
http://www.youtube.com/watch?v=rPSWi_z7M58
If motor grinding... etc., it means you may have a bad motor or plastic coupler.
Post further comments if you need more help....
Good Luck!!
Posted on Aug 24, 2009
Why does turntable rotate with door open?
The door switch could be stuck in the closed/on position. The electronic circuits could be malfunctioning. When the door is open, I sure hope than the microwaves cooking are not "ON". That could result in a very dangerous situation for you.
Dec 05, 2015 | Microwave Ovens
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
Microwave makes grinding noise when microwave plate on turntable
check for the roller spider under the plate
small plastic item that has 3 (4) rollers that allows the plate to turn freely
May 25, 2015 | Microwave Ovens
GE Profile Spacemaker XL1800 microwave turntable
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On some, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 28, 2013 | GE WB26X10037 Microwave Stirrer Motor
Sharp r-1850a turntable problems
turntable motor p/n 46-841666-3, available from searspartsdirect.com, use correct model #!!
Feb 09, 2013 | Sharp R-1850A Convection/Microwave Oven
Turntable makes grinding noise and barely turns
Unplug unit and take bottom off of it with the screws that go around the outer edge. The turnatanble motor has 2 screws and is removabe from the bottom underneath.
Sep 24, 2017 | GE JES1851 Microwave Oven
Loud noise coming from turn table
I have the same problem my microwave is a kenmore this is the second one I've had and they both did it I solved the problem by re-seating the turn table however if you are skilled at taking things apart you can put a few drops of small motor lubricant on the spline it worked for me. good luck!
Nov 21, 2008 | Microwave Ovens
It appears that the noise is coming from the the turning or spin-
You probably have a bad motor.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 20, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Profile Spacemaker Microwave - JVM1660BBC
The turntable has a small motor underneath it that rotates the glass tray. You could have a motor that is going bad, or the plastic spindle (what the glass plate sits on) could be slipping. You can access the motor through the bottom panel. Be careful to make sure the microwave is unplugged for attempting any repairs inside. There is potentially as much as 14,000 volts in the high voltage network around the magnetron. Let me know if this helps.
Jun 27, 2007 | GE JES1039 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
705 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
