Question about Gear Head WC535I Webcam
Why doesnt my Quick WebCam Advanced Model #: WC5351 work on msn?
My Quick WebCam Advanced Model #: WC5351 works when i turn on it's program but does not work with my windows live messenger. What do i do??
  • 1 more comment
  • autumnrwells Jul 19, 2009
    i tried while running both at once and i tried not and either way it does the same thing: it has a little black screen where i should be and its fuzzy
  • autumnrwells Aug 01, 2009
    i tried running both at once and it didnt work so i tried only one and it didnt work either.
  • are you running both at once ?
    Scholar:
  • 33 Answers
Step 1: The "Tools" menu of Windows Live Messenger
1. Recover Windows Live Messenger in our software if you do not have it yet.
2. Start the installation of the software.
3. Once this is done, go to the Tools menu software.
In this menu, two links are important in order to properly configure your camera:"Setting audio and video" and "Parameters of the webcam."This is the first that we will discuss first and foremost, the second used primarily to adjust the parameters of the image in the secondary stage but we are dealing with. Launch therefore setup wizard and click on "Next".
Step 2: The setting of loudspeakers
1. Select your hardware in the menu.
2. Check the box if you use a helmet.
3. Test finally your sound output in order to adjust the volume.
It is possible that you find in the menu several choices. That means you have several elements in your computer capable of transmitting sound, a dedicated card and your motherboard, for example. In this case, make sure to select well the correct input, what you quickly verify the test by loudspeakers.
Step 3: At the turn of the microphone
1. Select your sound source.
2. Start talking to your microphone.
3. Observe the cursor, if it moves, your microphone is working.
Two remarks on the stage configuration. On the one hand, if your camera has no microphone, you must go through a device that you must annex plug into the pink on your sound card. On the other hand, if your mouse does not work, you may have selected the wrong input device sound. Take particular care in this setting and not leave this page only when the cursor s'agitera,
indicating that your voice is recognized by the software.
Step 4: Turning finally to the image
1. Specify this time the source of the video.
2. Observe the window of return: if your setup is satisfactory, your image should appear.
3. Adjust the frame rendering through the "Option" button.
please rate me if it worked
Posted on Aug 06, 2009
    President:
  • 8,637 Answers
See section C. Windows Live Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next "Calling and Devices" on the right, set the Microphone and Speakers to the computer Audio Card or headphones/mike.
Next go to the Test Audio section below where you just setup the microphone & speaker and (written in blue) click on "Open the call setup assistant"
and the "Yahoo Call Setup Assistant" window will open to the left and follow the the instructions. Click on FINISH and the audio will be setup.
Next go to "Webcam" and click in the circle "Allways allow the following people to view my webcam.
Next Click on "Super Webcam" snd in the circle click "Start Super Webcam mode automatically".
Then click OK and it should work.
C. Windows Live Messenger:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window, click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Posted on Aug 27, 2009
Webcam doesnt work.
I wish I can help you Remotely, anyway try it yourself, reinstall the driver of your webcam and see the result. And remember to update with the latest version driver. Good luck.
May 15, 2010 | Acer Aspire 6930-6771 Laptop
Lifecam vx1000 msn problem
Try using a webcam sharing application like SplitCam or SplitVideo. These programs allow you to share a webcam across applications, and can also help solve compatibility problems.
Dec 28, 2009 | Microsoft LifeCam VX-3000 Web Camera
Hi I have a WC5351 bought in Aug 2009. It was
Download this diagnostic too and see what it finds
http://www.download32.com/webcam-diagnostics-d35065.html
Nov 16, 2009 | Gear Head WC535I Webcam
Problems with web cam on Toshiba netbook nb200
update the program ...if the webcam works fine on other IM programs ..it means that the msn is the problem ...
Jul 24, 2009 | Toshiba Satellite A205-S4617 Notebook
Dell webcam manager working with msn messenger?
as ive told others, make sure u actually turn off the software program that came with the computer before using with msn! u should be able to have it on while using it but for some reason some computers wont allow it! it "tells itself" that there are 2 programs trying to run the web cam when really only one is.
but because the program is on, it sees it as being used in 2 places at 2 different times!
try turning off and exiting the software (dell webcam manager) and then go onto msn and try using ur web cam!! make sure the dell manager is exited, then when u have a msn window open, turn the cam on and see if ur friends can see u then..
good luck..
if this doesnt work ill check back and see what i can do for you!
Mar 21, 2009 | Dell Inspiron 530 Desktop Computer
My webcamera doesnt work when i open my msn messenger,
u have to install driver of ur web cam....then in the setting of MSN messanger u should select ur caputering device (ur web cam model)then aplly...MSN will connect to ur webcam
Mar 08, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
Crystal Eye Webcam wont work on MSN!
your cam has to be setup on msn as well After you start Windows Live Messenger,
right side, click on “ “Show Menus.” And then click
on “Show the Menu Bar”.
Next go to the Menu Bar on right side, click on Action.
Go to “TOOLS” and click “Audio and Video Setting
let me know if this helped
Jan 19, 2009 | Acer Aspire 5610-4648 Notebook
Webcam wont let me do Video Effects?
If you have the "exact" same cam as your brother, and also use the "exact" same programs as your brother, then their is no reason why your cam would not work as your brothers.
Did you download the plug & play option for the cam?
Do you use the "exact" same version of windows as your brother? (Win 98, XP, Vista)
Nov 09, 2008 | Logitech Webcam
Webcam problem
I think ur laptop webcam driver not installed properly.If ur laptop have windows vista operating system then do these steps.
Goto Start - Programs - Recovery Manager - Recovery Manager.In that recovery manager,click on next.Its shows the Software reinstallation page.Click on next button two times.Its shows the software lists.Select the webcam software and click on next button.After reinstallation completed , u restart laptop and check it.
If ur laptop have windows XP operating system then u uninstall the webcam software through Add/Remove program and restart it.After restarting ,Reinstall the web cam software and check it. If u doesnt have webcam drivers then u go for nearest service centre and install it.
Thanks
Feb 27, 2008 | HP Pavilion dv6000z Notebook
Gear Head WC535I Webcam Logo
1,019 people viewed this question
Top Gear Head Computers & Internet Experts
micky dee
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
