Question about Linksys Wireless-N WRT150N Router
My WRT150N router works as long as I am hardwired. But, the wireless connection doesn't work.
  • 3,866 Answers
The radio is turned off in the settings or the radio is just malfuctioned ether way checking the settings in the admin page will shore up any issues you may have.
Posted on Jul 17, 2009
No wireless light
check the router setting in the outer page.. login wit 192.168.1.1 in ur browser.. before tat connect ur system hardwired to the router..
Jun 11, 2010 | Linksys Wireless-N WRT150N Router
Mu WRT150N Router appears to have stopped working. If I hook the modem direct to the laptop it works. If I put the router inbetween with the same direct connection, no internet. I have tried several cables...
Are any of the LED lights switched on in the router when it is powered up?
If not check the power adapter plug with a multi-meter, the output voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter.
If the voltage is zero or very low then the power adapter is faulty and needs to be replaced.
Dec 13, 2009 | Linksys Wireless-N WRT150N Router
Slow internet for my hardwired computer
its because ur belkin routers MTU is not properly configured in the products ... u need to lower doen the MTu speed ..
Sep 25, 2009 | Computers & Internet
Problem with VPNand Linksys router WRT150N
If that is the case you may forward ports on the router for VPN connection, try to open 47, 500 and 1723 all TCP and UDP protocol.
Here's what you need to do, check the IP address of the computer where you have the VPN software,
here's how:
click start> run> type cmd> hit okay
on the black screen put in ipconfig and check the IP address there,
> when you get the IP address then we can enable port forwarding on the router
> open IE on the working computer on the address bar, type 192.168.1.1
> nothing for username and password is admin in lower case
> then click on the applications and gaming tab on the router,
> and from there, example of how to field that in is like this,
> for aaplication name - VPN1
> for port it is 47 to 47
> for protocol it is BOTH
> for IP address ex. 192.168.1.XX - 192.168.1.100
> then check enable, do the same thing for the rest of the port.
> save the settings and try it again after.
> if it is still nothing, you may connect the computer that has the VPN connection directly to the modem and check if you will be able to connect via VPN
i'll wait for your response, thank you and have a nice day!
Jul 14, 2009 | Linksys Wireless-N WRT150N Router
WRT150N 0ccasionally wireless is lost. Repower gets it back
Where is the router located? There maybe devices that run the same frequency as the router that may interfere the wireless connection (e.g. microwave oven, cordless phone). It may help if you place the router in the middle of all your wireless computers, change the channel of your router (change it to channel 1 or 11), or securing your wireless network by changing your SSID (do not use default wireless network name as others maybe using the same) or use WPA or WPA2 to make sure that nobody uses your wireless network.
Jul 06, 2009 | Linksys Wireless-N WRT150N Router
Cannot access internet through WRT150N router wirelessly OR wired
Same problem here, the motorolla surf board works way better. It also coult be your ISP.
Apr 02, 2008 | Linksys Wireless-N WRT150N Router
Can't connect wireless to WRT150N.
Your hardware might not be compatible with eachother.
Mar 17, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-N WRT150N Router Logo
237 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
