Question about Ozaki DT-500 3-Piece Speaker System w/Subwoofer&Wired Remote (Silver) Computer Speakers
No sound i have a dell 9150, computer says everything is fine but i have no sound. Any advice?
    Problem Solver:
  • 12 Answers
The sound on 9150 is integrated, and can be turned on or off from the bios, go to bios and check if its off or on, download the latest driver from dell direct for your sound card, install the driver and restart the system, also check the plugs in back of pc that are connected, now try again and check if its ok now.
Posted on Feb 18, 2010
Good video, no sound with my dell dimension 9150
You can try to get the drivers off of your CD or you can download the drivers from here:
http://www.dell.com/support/drivers/us/en/19
1. Just choose "Select A Different Product"
2. Then choose "No, Choose from a list of all Dell products" and
select "continue"
3. Then select "Desktops"
4. Then select "Dimension"
5. Then select "Dimension 9150/XPS 400"
6. Now just scroll down and pick the drivers you need.
Don't forget to install your chipset and network drivers as well.
Jun 04, 2012 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I have a Dell dimension 9150 with 2 hard drives. The PC wont start up so I want to copy the data on the drives using USB 2.0 To SATA IDE Cable but when it reads the drive Windows says it can not read the...
It sounds like your dimension 9150 desktop has a primary and secondary drive.now when you say it wont start up what are you referring too?does it not power on at all, do any of the fans or lights come on. and also sounds like you got an external hard drive. now I got confused when you explained when it reads the drive windows says it cant read the drive. My question is I thought the pc would not start up? can you explain little more in detail, so i can try and give you the right advice?
May 26, 2011 | Dell Dimension 9150 (DIM915MIN) PC Desktop
My dell dimensions 9150 usually fails to start up and sends out a bleeping sound . It usually takes 3 to 4 attempts ( by switching the machine off at the on/off switch). Eventually it comes to life. Any...
The mother board is on its way out, eventually you will need to replace it. Before you do check the power supply, if you can get hold of one, test it and see what happens, you could also take it to your local pc repair shop and ask them if they could test it for you, if it does work fine then you will need a new power supply.
Feb 17, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I have no sounds when the computer is running. What to do?
goto dell support or call dell support and they will walk you through reinstalling the sound driver... if you installed a brand new sound card then you will have to install those drivers your self...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 23, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Alert PCI Express Card Is Operating In X1 mode
HI,
Just open the computer case and reseat the video card . everything should work fine . Over time some times the connectors of the video card may become oxidised. Check and reseat . Post back in case you need more help.
Thanks
Proton
Jul 03, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
My Dell Dimension 9150 will not turn on
Use your CD to boot up the computer and recover your operating system
May 05, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I have a dell 9150 and my sound has stoped working the volume control says that everything is on but i still have no sound.how can i fix this
Try updating the driver. If no luck there then remove the device from device manager and reboot the pc. Windows will reload it.
Jan 22, 2009 | Ozaki DT-500 3-Piece Speaker System...
Audio volume keeps changing by itself
No, the headphone output is designed for 2 speaker output. Just recently I had a customer who had no sound coming from the desktop speakers yet the headphones worked just fine.
I believe that your model has a sound circuit integrated into the motherboard. It may have a “plastic cap” covering the audio ports (next to the USB ports). If you remove the sound card and enable the integrated audio in the BIOS, you can check to see if the sound card is actually the problem.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 16, 2008 | Dell Dimension 9150 (DIM915MIN) PC Desktop
82 people viewed this question
Top Ozaki Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ozaki Audio Player and Recorder Expert? Answer questions, earn points and help others
