SOURCE: Setting tax rate on a canon P170-DH
To set the tax rate, slide the "GT" switch to RATE. Enter the tax rate (i.e., 4.5 for 4 1/2 %). The display should show 4.5 %. Slide the "GT" switch to OFF.
SOURCE: Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
SOURCE: Canon P170-DH calculator
http://downloads.canon.com/cpr/software/calculator/P170-DH-(USA-HWB).pdf
SOURCE: I need to set the calendar and date on calculator
Download the P170-DH Calculator Instruction Manual and folow the instructions.
SOURCE: Changing Ink in the Canon P170-DH Printing Desk Top Calculator?
The manual for the Canon P170-DH calculator is found on the canon usa web site. It is 22 mg in size, but prints out to 4 pages in English, Spanish and French.
According to the manual: Use only Ink Roller CP-13.
There are four figures showing the steps, so you'll have to imagine it.
1. Turn power switch off.
2. Remove the printer cover (Figure1).
3. Hold the tab of the ink roller. Lift the ink roller out of the base (Figure2).
4. Insert the new ink roller into position. Push down on the center of the ink roller until it locks into place (Figure3).
5. Replace the printer cover (Figure4).
Print out the manual for yourself and put it in a safe place.
